E-bike cover help (1 Viewer)
Jun 25, 2012
267
77
Low profile
Joined 2014
We have 2 ebikes dutch handlebars bought a cycle cover from sewandsos and its so heavy takes an hour to put on any ideas please we have a fiamma bike rack offset because of ladder about 100 MM. sticking out from side of van
We are going away to Holland next weekend and we bout a fiamma premium s but it's so complicated to put on cannot find any instructions anywhere I have noticed other fiamma covers whilst being on sites with bungee but not sure which model I need or should I persevere with the premium s if I can find instructions
Any help would be very welcome
Daveg
151
165
Perthshire
Low Profile
November 2012
Do you still have the box? There are six pictures on the RH side which is all the help they offer. Pretty useless but number 1 is the key. Because the cover completely encloses the bikes, you have to figure out how to get it onto the bike carrier before you lift the bikes on. The key is to open up the velcro flap and slide the back of the cover around the carrier on the van. The flap goes above the cross piece and hangs down between the vertical tubes. If you get that bit right you can lift the rear of the carrier up to handlebar level when the bikes are on.
Sorry it is very difficult to explain. I got there after quite a lot of trial and error. I have some photos which might help. PM me your email and I'll send them
Dave
K
Jun 25, 2012
267
77
Low profile
Joined 2014
Thanks have worked out how it goes on but is far too heavy material canvass that the sownsow one I've also tried the fiamma with Velcro at back that's much lighter but takes ages to do
Fiamma do basic cover with bungees does anyone know what they are like
54,255
153,430
When we had a bike rack we had one of those, useful as it fully encloses the bikes so you don't get all the road much thown up on them.
Know what you mean about putting it on, one day it goes on in minutes next time you try half hour later given up and about to throw it in the bin. Trick is once you have got it on when you take the bikes off don't take the cover off leave it on the rack just hold it on the wheel supports with a bungee or two then it is easy to pull back over the bikes.
Also water tends to get in a bit via the zips and you end up with a big puddle in the bottom, so I made a couple of holes in the bottom about 3-4mm dia. so it self drained I used a soldering iron but a hot screwdriver would work.
Daveg
151
165
Perthshire
Low Profile
November 2012
OK. We used one for our old (non electric) bikes. They wear through at pressure points and the bikes get a lot of stuff on them because they are open at the back.
Much prefer the Premium because the electrics are better protected, even though it is a faff.
Steve N Tracy
1,246
3,774
Southampton
4 Years
We bought a Fiamma Premium S and the first time we used it in the rain it ended keeping more water inside it then outside,
the material is not very waterproof, I would certainly not use one with E-bikes.
We have a Taylor made one now its heavy but keeps the water out.
SMB
Apr 26, 2013
1,236
1,355
Spain
Coachbuild
Fulltiming since February 2013
I bought one of these in Austria last year due to the Fiamma cover falling to bits and ripping, had no problems with this one. Very strong material and once its on ts easy to load and unload the bike. I bought the concept fully enclosed version although the shop didnt have the straps so I use bungees. Water can still get in but its simple to just unzip and force out the pooled water. Never getting a Fiamma again, they're rubbish in comparison:
http://www.vancomfort.co.uk/bikeandcarriercovers.htm
Jul 10, 2014
179
57
Cheltenham
Elddis Encore 255
3 years
We found the Fiamma premium a complete pain. Took ages to discover how to fit when we first had it. Even now we know the way it sometimes takes forever. Material poor and soon began to wear. Not waterproof as rain would puddle and enter via the zip leaving a pool inside. Ideal atmosphere for rust!
For 2017 have replaced with a standard Fiamma which covers adequately and fits easily in a few minutes. The only downside is poor quality material so take care with any sharpish bits like the brake levers
We have the standard cover for 2/3 bikes but it certainly wouldn't take more than 2 bikes. We have 2 largish electric mountain bikes and they fit OK.
Feb 28, 2016
487
962
Eldiss autoquest 175
Only just read this, best thing I have to help fitting the bike cover is this, its light weight and I bungee strap it to the rack between the wheels before fastening the cover.
Amazon product ASIN B003N9CMPQ
