Ducato x250 radiator change. (1 Viewer)
Johnnyb
149
139
Yorks/Derbys
Has anyone changed the radiator on a 2.3 engined x250 & can give me any pointers before I start? I've found quite a few guides for the previous shape Ducato but none for the x250.
The problem I've got is a small amount of coolant dripping off the intercooler which is fastened to the bottom of the radiator. I've had a very quick look at the hoses which all seem dry at the clamps so suspect the radiator is at fault.
DanielFord
3,020
3,086
I could be wrong, but I think you have to remove the front bumper first, then you can get at the rad.
Johnnyb
Johnnyb
149
139
Yorks/Derbys
Thanks for the replies so far.
Yes, using water and having to top it up occasionally. I've followed the overflow pipe but it disappears into an area I can't see properly. Not spotted the fan switch yet. The radiator itself is pretty difficult to see, it has the fans on one side, the air con condenser on the other and the intercooler along the bottom.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Yes I've done a couple of X250 rads, one on my own van.
Open the bonnet.
Remove the front grill panel.
Remove the slam panel.
Remove the cap from ther expansion bottle/header tank.
Disconnect bottom hose and drain coolant.
Disconnect top hose.
Disconnect fans.
Lift rad out.
Reverse procedure and refill with fresh coolant.
Unless you know its been done within a couple of years I'd replace the cambelt and water pump while you've got the front off becaue access is so much better with all that bodywork out of the way.
Rad swap according to Autodata is 1.35 hours.
D.
Johnnyb
Johnnyb
149
139
Yorks/Derbys
Thanks for the links and suggestions everyone, really appreciate it.
To answer a few questions, the van is 6 years old and has covered 19000 miles. The antifreeze is ok and the cambelt and water pump were changed just over 2 years ago. It does seem quite rare for the radiator to fail on the x250 as there is hardly any info about but I'll be giving it a very close going over before I start tearing it to pieces :LOL:
Johnnyb
Johnnyb
149
139
Yorks/Derbys
To give an idea of the topping up required, a 300 mile non stop journey will see the level in the header tank drop around 2cm so not losing gallons but enough to raise concerns. As mentioned, I can see coolant dripping off the bottom of the intercooler (which is on the bottom of the radiator), what route the coolant is taking to drip off the intercooler is the puzzle.
Dec 16, 2019
77
239
Old thread I know, but I've got exactly the same issue.
What was the outcome? Did you change the rad?
Apr 22, 2018
6,825
12,585
Herts.
Adria Coral lowline
I’ve changed mine and there are a few variations of X250 rads. You will need to know what you’ve got, and what you want. 👍🏻
Apr 22, 2018
6,825
12,585
Herts.
Adria Coral lowline
Some sites have full engineers drawing for the rads which is a great help. Main points on the 250 were the thickness and the size of intercooler mounts on the bottom from memory. There were also massive differences in cost when looking into it.
Jan 28, 2016
2,499
2,934
Stockport, Cheshire
Bravaria i740 AClass
My Citroen relay work van looses about 25mm in header about every two to three weeks. Nobody can trace the leak so i top up every week if required no problem.
Dec 2, 2019
4,103
9,160
South Lincolnshire
Rapido 7065+
Broken most bits now
I'd never recommend using it over changing a rad but I've chucked some in a few cars to get by with generally good results and no bad things happening. Usually the repair lasts as long as I have the car (between 1 day and 2 years 😉) The Radweld I'm used to is pretty thin and pours easily but there are different flavours of the same thing out there.
Dec 16, 2019
77
239
I used radweld on an old escort and it did the trick, not willing to stick it in my van!
Feb 15, 2014
713
1,249
cambridgeshire
Bessacar E450
3 years
K seal is what you need, had a leak on the heater of my x250 work van put 2 bottles of k seal in 6 years ago and had no problems since then
Sep 9, 2019
857
1,904
Runcorn
Autotrail Apache 632
Since Sept 2019
We went to northern Spain in my MX5 mk1 (see Avatar to the left). The temp guage went through the red zone and out the other side as we neared the channel tunnel on the way down. I suspected a sludgy radiator. We ran no faster than 80mph on the French motorways in full July sunshine with the lid down and the heater on max blowing through the windscreen vents. I had phoned the guy I get all my MX5 bits from whilst still in the chunnel carpark and he said a replacement rad would be £35 plus around the same for delivery to Bilbao. I gave him the Spanish address and the bloody radiator got there before we did! I found a nice high kerb in a nudist beach car park and swapped out the old one. I always carry a basic set of tools, socket set, spanners, screwdrivers etc. so it wasn't difficult to do. Took a bit longer than I expected though as the views were so appealing........:giggler:
How did the original OP get on? Did he get it fixed? I hate it when you follow a thread for ages and don't get the final chapter, it's a bit like someone nicking the last page out of your holiday novel!!
Cheers!
Russ
Dec 16, 2019
77
239
RustyRuss Funnily enough I'm in southern France and I'm weighing up my options... I think I may well do it down here or at least get it so that if it does go I can do it!
Apr 19, 2008
1,945
2,925
Kent coast Hythe
Rapido fiat based
brought first van 16 yrs ago
How did the original OP get on? Did he get it fixed? I hate it when you follow a thread for ages and don't get the final chapter, it's a bit like someone nicking the last page out of your ho...........
Russ
HOW DID THIS END.................
