Ducato headlight stalk (1 Viewer)
Badknee
7,407
412,780
notloB
Vantage Neo
Living the dream.
The headlight switch is throwing a wobbler sometimes, it's fine on sidelights (1st position) but when I go to headlights (2nd position) either it works ok or it turns all the lights off, dash included.
The question is has anyone stripped the stalk down to clean the contacts and is it even possible?
Thanks in advance (y)
May 31, 2015
11,682
44,525
Cornwall
Ducato PVC
Getting Better
There's not a lot to them Paul, take all the cowling off and have a good look and clean as necessary, could be a loose earth, if no good then another from a scrappy won't be much..
Dec 12, 2010
5,412
21,566
Cumbria
since 2011
I stripped down the indicator stalk on my Renault, the left hand indicator was on all the time unless you selected right turn. There were a couple of springs and cams, nothing too complicated, but don't strip it down over the shag pile carpet in the living room. All the contacts were great and the moving parts worked as they should but the fault appeared to be within a section of inaccessible moulded plastic that held four of the contacts. I only discovered this once I'd got a second hand unit (£20) from the scrappy and began swapping bits over.
Emmit
8,034
17,753
Cornwall
Pilote Explorateur
Jan.2014
I'm about to post elsewhere on here, but, from what I've discovered about Fiat's, your stalk could be generic, ie fitted to other Fiats, THAT AREN'T MOTORHOMES!!!
That may become very relevant, if/when you come to replacing it.
I have just had a lovely chat with Jim at New Milton Autoparts in the New Forest. If there is a crossover in stalks that man might save you a shedload (I have no connection with the Co.)
Badknee
Badknee
7,407
412,780
notloB
Vantage Neo
Living the dream.
Thanks for your help guys........ except Garry Smiff who's about as much use as a chocolate fire guard, anyway it was your handbag you left there in the first place :LOL::LOL::LOL:
I have been having a mess with it and it seems to be the end of the stalk that is the problem and I'm wondering if the contacts are up the stalk Ooooer Mrs :eek: or is there a rod running down the length of the stalk and the switching goes on near the steering wheel boss, any ideas @jockaneezer ?
Dec 12, 2010
5,412
21,566
Cumbria
since 2011
Hi @Badknee, on mine, the rotary action of the switch travelled down a rod and all the switching took place in the "box" that's on the column end of the stalk. I found a photo of the unit on my phone, the white plastic part with the small coil spring is the indicator "return to centre" unit and the other white plastic rectangle with the copper contacts either end is the indicator switch which slides from side to side via a long central shaft with a dogleg end which engaged in the square cut out in the back of the rectangle.
Badknee
Badknee
7,407
412,780
notloB
Vantage Neo
Living the dream.
Thanks @jockaneezer, that's great. I'll have a look tomorrow and perhaps it's just a dirty contact. It worked fine today when I tried it but the other day the headlights wouldn't come on at all and it switched all the light off :swear2:
TheBig1
17,630
43,279
my next door neighbour has not long since retired from working there and a friend drives the delivery van
