Ducato ball joints (1 Viewer)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Can anyone confirm if this is big enough to split my balls :roflmto:
Broken Link Removed
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
Should be but you cant need a ball joint yet surely
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes matey
MOT examiner showed me today even though he passed it.
It makes sense really as it is the same side that had a smashed strut top bearing and knackered damping. POT HOLE in France last year. Strut came to light when having new upgraded coil springs fitted.
BTW that is the most expensive ball joint at £34 :roflmto: I could have the choice of two at a tenner each :Eeek:
3,213
2,535
North Hykeham
Custom
much more now
All you actually need is a large hammer.....and hit the end of the swinging arm (not the ball joint).....worked everytime for me for 30 years in the motor trade.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
I too have used the "hammer on the end of the arm" for over 30 years but with light commercials I have come across plenty of cases where it just didn't work, by the way I use a three pound copper/hide mallet on copper side rather than an actual hammer. I have a splitter like th one Techno has shown and that, along with a "judicious whack" from the copper mallet has never failed...........................yet.
D.
May 16, 2010
3,213
2,535
North Hykeham
Custom
much more now
I'd rather not :Eeek:
Lol...coward..::bigsmile:
I remember coming from college and my forman asked what I'd been doing and I replied "ball joints" so he said right you can go and do that 100 over there it needs them all doing...(in those days you adjusted them with shims) so I asked him where he kept the ball joint splitter and he handed me a 1.5 pound hammer and I looked at him gone out....then he showed me the technique and I never looked back...:thumb::thumb::thumb:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
As a 17 year old I spent ages with a hammer trying along comes dad hgv mechanic/driver tells me I am not hitting it hard enough one whack from my old dad and off she came.
Boy do I really miss my dad:Sad:
chrissyvine
62
56
Devon
Since 1992
Just realised I've been reading about a load of blokes discussing their balls!
:ROFLMAO:
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
If its a really tight one use 2 hammers in opposite directions at the same time.
Via BT & Fon from Thaon les Vosges.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Andy on the tool you linked I am guessing the 20-50mm is the Gap from the yolk to the compressing arm if that makes sense so if you measure your new one is that any help?
edit these explain the measurements
Broken Link Removed
Broken Link Removed
its as I thought
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Should be the thickness of the suspension arm plus the length of the ball joint thread that protrudes through.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Those type are really for joints that are to be saved/reused.
For knackered ones you can use one of these type
Broken Link Removed
I still use a hammer where possible though.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes I know but at some point I may need new suspension arms :thumb:
MOT in 2013 said my rear bushes were perished :roflmto: lying tw@t still ok now but he offered to fit new ones for over £600 :Eeek:
Hence I found an honest garage this time.
I now use and can't speak highly enough of these peeps
10,117
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
ive always used a bar and hammer but motors are so flimsy nowdays there often nowhere to lever against the days of the chunky chassis is past
43,331
49,467
even using a splitter be prepared to use a hammer as well.
The compression splitters dont always pop the joint.
These work every time but do damage the joint so only use if joint to be replaced.
Broken Link Removed
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Here is that bad boy :roflmto: He'll be getting Techno'd soon :thumb:
BTW the splitter I bought probably doesnt have a wide enough jaw but I'll file it out. It is 20mm I believe but probably needs to be about 24mm
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
From memory so I could be off the mark here but the balljoint nut is 24mm AF so the threaded bit will be about 16mm dia? Your splitter with a 20mm jaw width should be ok. When I've had to use mine I generally find that winding a fair bit of pressure on it will not crack the joint but then givng the tail of the splitter a couple of good cracks (think like trying to drive a wedge in) with a 2.5lb copper mallet will break it apart. No wonder my wrists are knackered:cry:.
D.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
The ball joint shaft is tapered Dave so on the opposite side of the track control arm to the nut it is very much wider.
Of course I will try it before the need to customise :thumb:
