Drilling plastic solar panel corner brackets (2 Viewers)
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
I have opted to fit panels on my roof using plastic corner brackets. The brackets arrived today and I am quite surprised that they are made of very rigid/brittle plastic. I am wondering the best way of drilling the holes required without cracking or shattering the plastic. Am I being overly cautious? All recommendations welcome.
Lenny HB
53,430
149,993
On the coast in West Sussex
Hymer B678 DL
They normally come with holes to mount the panel you shouldn't need any more holes.
Plastic is easy to drill just make you use a good quality drill & medium speed.
Flamenca
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
Unfortunately, the brackets I bought on Amazon did not come pre-drilled.
Jul 13, 2008
3,739
3,864
Low profile
Obviously not these then? Thought they all had holes pre drilled?
Flamenca
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
@Boringfrog I bought them from a different supplier on Amazon. They look identical to the ones you show but no holes pre-drilled :(
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
The recesses for the holes look too near the corner in my view and the drill will hit the steel reinforcements within the panel corners.
I use Aluminium
Jul 13, 2008
3,739
3,864
Low profile
I would drill with a small 2mm bit 1st then use the correct size for the bolts you're using. Are they curved like the photo too?
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
I'd get some silkaflex and stick em down(y)
Terry
11,932
9,083
Lincolnshire
Can't remember ;)
May I suggest you simply stick them on your van IE no drilling -Mighty strength grip and grab -made by Siroflex is great stuff(y)(y)(y) but takes a bit of finding -Also Puraflex 40 (y)from toolstation is very good for both sticking and sealing
terry
Flamenca
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
Yes, identical to the ones in your photo. As you suggest, I will drill pilot holes initially.
Techno
Jul 28, 2010
15,475
20,756
May 2010
terry
He means to fix the bracket to the panel Terry not to fix to the van
Flamenca
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
Fortunately, or possibly unfortunately, there are no steel reinforcements within the corners on my panels. They are cheap ones from China.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Not that you can see but yes there are inside the aluminium which is hollow double skinned
Reactions: DBK
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
Make sure the plastic is warm, not cold and brittle. Keep overnight in a warm place prior to fitting should do it.
And buy new drill bits, especially if you have to drill through the corners which as suggested are likely to be solid. It can be done, I've done it. The screw nearest the camera on the far panel in this shot goes through the corner reinforcing and I have used an M5 bolt there.
Techno
Jul 28, 2010
15,475
20,756
May 2010
See the rivet is inside the double skin
and you can just see one of the indent marks that crimps the aluminium to the internal corner joiner
Techno
Jul 28, 2010
15,475
20,756
May 2010
Be sure to use a course grit sandpaper on the base of those brackets before applying adhesive
Jul 28, 2008
813
731
Wiltshire, UK
Ducato Sportivo
Since 2005! 2000+ nights so far...
I've got the same brackets in black, and plan to use 2x corners and 2x straight bits. As you, neither have pre drilled holes.
Aug 20, 2007
574
637
Leyland
Frankia I7300 BD
since 1997 (many years tugger before then)
Usually drill half a dozen holes through the aluminium brackets, this allows the mastic sealant to ooze through and give added 'stiction'.
Allen
Techno
Jul 28, 2010
15,475
20,756
May 2010
Allen
I was referring to his plastic brackets
No I don't pepper pot the aluminium I use sika cleaner activator no need for holes
