DPF Cleaner Fluid. (1 Viewer)
May 7, 2011
5,960
31,661
East Anglia
Kontiki 669
Since 2010
I have the glowplug light that comes on and then that leads to the engine light and then goes into limp mode.Some times it clears itself,but the light
always comes back on.
So I have been recommended to use this product from Wynns.
Amazon product ASIN B008VQMLXE
I have read all the reviews and they are mostly giving good results.
I have not used it yet,and will report back with results when I have.(y)
43,331
49,465
Why ?
All it needs is high revs (2500 to 3000 rpm) for 15 minutes to produce enough exhaust heat to clean the DPF.
Go for a run and leave the box in 4th gear.
Jo662
May 7, 2011
5,960
31,661
East Anglia
Kontiki 669
Since 2010
Why ?
I have done that a number of times,and all it does is bring the
engine light on as its telling the engine it has another fault!:oops:
tonka
10,833
21,532
Cannock, Staffs
A class Burstner 800
Since 2000
Rev the bo****s off it all you want... Tip in as much cleaner as you want....
At some point Fiat computer will say "NO".. and something will need changing...
Went to Benidorm and back in mine, revving hard, used cleaner, cleared faults with OBD reader...
Gave up on the last run in to Calais dock.. Managed to limp home.. JUST....
New DPF sensor fitted and (fingers crossed) run fine since.... Local garage £150.
tonka
10,833
21,532
Cannock, Staffs
Since 2000
Why ?
Not always, my van never sat about did 20k plus in first 2 years.. Nowt I know for a diesel van but reasonable for a motorhome.. Still had the DPF sensor problem and no amount of high rev running or cleaner worked for me.. :(
Jo662
May 7, 2011
5,960
31,661
East Anglia
Kontiki 669
Since 2010
What cleaner did you try Tonka?
tonka
10,833
21,532
Cannock, Staffs
Since 2000
Sorry.. Cant remember, was back last summer 2015...
Tried the hard running and cleaner but no good.
Gave it a blast to Benidorm and ran ok to Valencia then light came on and new errors showed.
Had my hols and chanced it back, On return had to clear faults but on last morning just before the ferry it almost gave up on me, managed to get on ferry. Luckily it started, ran a bit low powered but got me home..
Search DPF all the info ref the sensor should be on here somewhere..
43,331
49,465
Then it's not the DPF, it has to be a faulty sensor or the filter is completely blocked and nothing will clean it.
If my mercedes engine doesn't regenerate through driving the ECU forces a regeneration.
Why this isn't a function of all engines beats me.
Steve and Denise
5,294
14,092
Spalding LINCS
A Class Carthago
Since 2008
I think most Fiat owners around that era had new sensors fitted due to faults coming up.
Just for the record when the light came on in my van the engine would not rev above 1500 rpm so that blew the shit out of just rev it up and it will clear its self.
43,331
49,465
You have to clear the fault code causing the limp mode first, then it will rev.
Steve and Denise
5,294
14,092
Spalding LINCS
A Class Carthago
Since 2008
The AA man cleared the the fault but after a miniute the light was back on at the end of the day the sensor was faulty and was replaced as the light just kept coming back on.
TerryL
6,187
8,190
North East
Low Profile
How old is your van? There was an issue with the early X250s, 2007-8, with water ingress onto the engine which has resulted in various problems connected to the breathing system.
Just ended a 6 month saga with ours with similar behaviour, final solution was throttle body replaced although I've heard of EGR valves being changed as well. I bit the bullet and took it to a Fiat main dealer who identified the problem on the analyser and sorted it. You can spend £100's with garages who "know what is wrong" before it's sorted - yes Fiat were expensive but they sorted it first time.
Take it to a dealer.
Mar 29, 2011
961
639
Rugby UK
C Class RS
I put a Wynns gold treatment in my last Iveco 3 litre and it did have a positive effect, both on the sensors and the readings at a main dealer
Neckender
3,221
5,921
Neckend or North Wales.
VW T6.1Kombi day Van
Since 2004
Ran mine at 3000 revs in 6th gear and shot down the A50 at 85 miles per hour.:eek:
John.
Steve and Denise
5,294
14,092
Spalding LINCS
A Class Carthago
Since 2008
I know this is an old thread but last week pulled off a duel carridge way after travelling at 70 mph in to slow moving traffic and yes the engine light came on switched the light off no changh the van was in limp mode but reved to 3,000 rpm just but no umph went 35 miles like that no change,
Set off home this morning with Whyns dpf cleaner in the tank after a few miles we could smell a parifine smell strong the van reved as normal pulled well but the light stayed on no detriment cleared the light all ok now.
I have never been an advocate of fuel additives but this may have proved me wrong at the end of the day the manufacturers can not get it right and want to charge us for it, Fiat said it could cost near 2K worst case sinareo.
tonka
10,833
21,532
Cannock, Staffs
Since 2000
Deleted... Hobgoblin overload..
Don't read fun when p****ed. ....
Stupid me...
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
I don't have a DPF in my petrol engined motor home. :whistle: :rofl: :moon2:
Scattycat
920
1,262
Mayenne, France
Rapido
Since 2010
If you have the engine management light coming on on a regular basis I suggest you take it to a dealer and get it checked out.
I had the same problem for a year or so and kept adding cleaner and also using a gismo to camcel the fault code.
It turned out it was a known fault that the manufacturers should have corrected on a recall though we were never advised of it. The problem eventually caused a catastrophic engine failiure, and because I'd had my servicing done privately the engine manufacturer refused to accept any liability, so I had to fork out for a new engine.
A few quid spent getting the dealer to check it out may be worth it, for peace of mind if nothing else.
funflair
19,363
30,274
Guisborough
MORELO palace
since 2012
At the commercial vehicle show at the NEC last week and talking to a guy from Green Urban, they clean DPF's for truck's, while we were chatting he said they had a fluid that seemed to work very well on motorhomes for some reason, he did offer me some but we don't have a DPF.
Guy is Brian Firth.
Martin
TheBig1
17,630
43,314
forte is the go to brand for many workshops. I had an issue on my Navara a while back. on advice, I used some forte injector cleaner in a part tank of diesel and took it for a decent drive. It made black smoke on acceleration for most of the journey, but the power was back to what it should be
since then every other fill up I use premium diesel with the extra cleaners in. Now the Navara drives like new again with no sign of smoking. somebody with many more years experience with diesels than me recons its down to cheap supermarket fuel and not working the engine hard enough to burn off the dirt doing too many short journeys around town
Jun 17, 2012
2,933
9,931
North Essex
Autotrail Delaware
>12 but <13
Get an independent garage to check the Trouble codes. My sons' often use the diagnostics machine that does a forced re-generation. You won't want to watch/listen as the engine winds up to 4000 rpm and sits there like that for several minutes. :Eeek:
Bit of smoke but clears the problem and turns out the EML.
Assuming that is what yours requires.
I did a history print-out on mine, told me how many re-generations done, next due, state of oil, when service due based on type of use, mileage at last service, etc. etc. several pages in fact of various details.
Steve and Denise
5,294
14,092
Spalding LINCS
A Class Carthago
Since 2008
Ok light came back on this morning cleaning fluid looks like it may not of worked:(
