Dometic fridge removal (1 Viewer)
Murphy
92
53
Mansfield
Shire Conversion
I have noticed a water leak from rear of fridge area, possibly from tap or connections, has anyone taken out a Dometic fridge from a Autoquest 130 and is it pretty straight forward ?
Murphy
Murphy
92
53
Mansfield
Shire Conversion
There is 2 vents which I have removed , but unfortunately unable to see to floor level, thanks
Wobby
83
55
Hailsham
I've had to take a tec tower out once and imagine yours wouldn't be much different. There are screws that hold the front edge of the fridge to the wooden frame once these are removed and the gas/electric is disconnected the fridge should slide out quite easily.
Wobby
Murphy
Murphy
92
53
Mansfield
Shire Conversion
Appreciate your reply Wobby, will be giving it a go tomorrow when back home,
Feb 24, 2013
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
Hope yours is easier than ours, tried to remove fridge freezer, found and took out the screws mentioned above, still wouldn't budge, our tower includes the oven, all three are attached to each other and come out as one. We gave up
Good luck (y)
funflair
19,349
30,240
Guisborough
MORELO palace
since 2012
Make sure that the condensate drain from the fridge goes into the evaporator tray and not missing and going onto the floor, it should show in the lower vent.
Murphy
Murphy
92
53
Mansfield
Shire Conversion
Thanks funfair, I will check when back, noticed on YouTube it shows the top vent has a small pipe that requires removal from vent slot prior to unscrewing and pulling out,
Regarding the water at back, it Is definitely coming from the taps or tubing, as when running pump you can hear it spraying at back and is dripping through back of van onto floor,
We have emptied the water tanks to ensure we do not use it any further until we have checked what problem is,
