Dometic fridge freezer (1 Viewer)
Andy 700
8
Rapido 996M
Hi all,
we're currently travelling East through Northern Spain and after setting the fridge to 12v for a leg of our journey forgot to turn it back to gas, doh. After several hours away from the van, realised mistake and re set to gas opperation. Batteries were fine but since the fridge has got warmer and warmer. The freezer is still a little cold but looks like we're going to have to throw or eat the lot. Any ideas people?
DBK
18,029
48,100
Plympton, Devon
PVC, Murvi Morocco
If it was working on 12v but is not now it is on gas this narrows down the cause I think. The gas burner might be choked with carbon so you need to get at the back of the fridge and try and clean it out - it may need nothing more than a good blow. On our fridge there is a gauge with a needle which moves into the green when the gas is lit. Do you have one of these and if so what is it doing?
A
Andy 700
8
Rapido 996M
Will have a look at the gas burner in a moment and see about a build of of carbon and get back to you. Thanks for the quick response.
A
Andy 700
8
Rapido 996M
Devon beekeeper, forgot to mention , we don't have a gauge.
A
Andy 700
8
Rapido 996M
Icantremember, sounds like a good idea, just one snag, warm beer........yuk
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Our fridge is a Thetford and it has a viewing flap in the chimney which is accessible by removing the lower externl vent cover ... yours being Dometic may be different but I'm sure there is a way of viewing the flame to check if it's burning cleanly.
Just a thought, is your regulator ok and do you run the fridge on Autogas from a bulk tank?
A
Andy 700
8
Rapido 996M
Gas is lit, automatic ignition and you can see the flame when vent removed, also combustion chamber and pipes hot. I have given the ignition area a good 'mk 1' lungful of high speed air and was repayed with a cloud of dead flies and rust. Will wait 5 mins and see if there is any breakthrough.
A
Andy 700
8
Rapido 996M
Running fridge on auto gas at the moment although I do have a propane cylinder for emengency use. Cooker is run on same supply and working fine.
A
Andy 700
8
Rapido 996M
Fridge warming up not cooling down. Fridge was left off 48 hrs ago and been getting warmer since. Freezer fairing a little better but obviously colder to start with.
icantremember
8,333
17,545
Hymer T-SL668
since 2005
I understand from my service engineer that auto gas can be slightly oily and Dometic fridges are particularly susceptible to sooting up the gas jet .... so if it's not cooled down sometime soon worth checking the flame is burning cleanly (should be blue) and clearing the jet. Don't poke anything through the jet as they are very fine and easily damaged.
flatpackchicken
1,277
1,757
BICESTER OXFORDSHIRE
A Class Frankia I8000
Since nov 2009
Have you tried simply turn fridge off completely wait a few mins select gas and turn back on again, as you changed over the working manually and may have upset the automatic selector??????? just a thought Regards Garry Flatpackchicken
icantremember
8,333
17,545
Hymer T-SL668
since 2005
Can you get it on to ELH for a while to ensure the fridge is ok and the themostat or thermistor is functioning?
Oct 29, 2008
5,070
5,973
West Yorkshire
PVC
since 2008
Exact symptoms of a blocked jet. There are instructions on a thread somewhere on the forum, on how to clean it.
A
Andy 700
8
Rapido 996M
I think if the pilot is lit then this shouldn't be an issue, but willing to give it a try once I've seen if the improvised air cleaning technique has worked. Thanks Garry
