Dometic Fridge/freezer: not working on 12v (1 Viewer)
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
We have a Dometic auto switching fridge/freezer in our camper. Just noticed as we passed through the tunnel that as we switched the gas off that it didn't switch to 12v on it's own. Played about with it but couldn't get it to work on 12v even if we manually selected it.
Are there any obvious things to look for before i start getting the tool box out ?
Wondered if the battery was too low (was showing 12.9v) but can check that today as they should be back up to full power.
Any tips appreciated
scotjimland
2,335
10,108
A Woosh bang
The 12v supply for cooling is fed from the chassis / engine battery, via a split charge relay .. not the leisure battery..
It only has 12v power when the engine is started.. that is how it is designed to work
Badknee
7,408
412,824
notloB
Vantage Neo
Living the dream.
What the lads said. Just keep the door shut and enjoy the trip. (y)
Feb 24, 2013
13,083
101,452
Bolsover, Derbyshire
Hymer S800
not long enough
be very grateful it didn't, our first MH had been incorrectly wired and allowed the fridge to run off the cab battery with ignition in radio position, found out ourselves on the tunnel
had to be recovered on the train, very embarrassing
as already said above, it should only run when engine is running
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
So in summary just more Ridgeway muppetry......
ok will check it this evening must I'm sure it's just that (lets hope)
Think I was getting mixed up with the tintent versions which you switch manually but still run if the car engine is off (I think?)
Badknee
7,408
412,824
notloB
Vantage Neo
Living the dream.
No, gas or mains leccy when stopped. 12v when on the move. (y)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
It must of course be set to AES too
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
Thanks Paul, that's great.
PS: how do you survive "up norf" since I we arrived in Manchester 2wks back it seems to have never stopped raining until we left on Saturday...
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
Thanks, another small job for the list.
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
Yes we have both options on ours, AES or manual but I wasn't aware of the engine running requirement
Techno
Jul 28, 2010
15,475
20,756
May 2010
can he not manually select 12V? we can on ours anyway (y), or as you say leave in AES and let it sort itself out :)
Yes of course but I was responding to........
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Lucky you, usually snowing this time of year which stops the whippet and pigeon racing (y)
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
and to confirm that with engine running and gas off that it does Indeed switch to 12v.
thanks guys
Minxy
32,659
66,565
E Yorks
Carthago Compactline
... under your own steam of course (ie engine running) ... not moving on the tunnel express! :D
