Dometic AES fridge buzzing problem
Discussion in 'Tech/Mech General' started by OldAgeTravellers, May 1, 2016.
  1. OldAgeTravellers
    OldAgeTravellers Funster Life Member
    Jan 6, 2014
    382
    239
    Languedoc, France
    Dometic AES fridge buzzing problem.
    HI we have the above fridge the large one with separate freezer. When driving on battery it has suddenly started buzzing after about ten minutes as if a relay is chattering. So we have to switch it off while driving then remember to switch back to gas. Which for short hops will be ok but a long drive will be a problem for the fridge. And it is difficult to duplicate whilst stationary
    Has anybody had this happen to them and found a solution?
    The van has started to hit back as we have just decided to buy a newer one with bigger payload and loads of things have started going wrong.
    Hope somebody can help.
    Steve
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,224
    15,205
    Leeds the one up North
    If it's the older 7 series mine had a 30 amp automotive relay on the back at low level which switched the 12 volts from the alternator
  3. OldAgeTravellers
    Jan 6, 2014
    382
    239
    Languedoc, France
    Thanks Andy, the buzzing seems to be coming from behind the control panel at the top of the fridge not from the back. There may be a relay on the board on there which is emitting this high pitch buzz.
    Really wondered if anybody had experienced and found a solution.
    Steve
