DIY through the roof WiFi in pictures (7 Viewers)
Welsh girl
3,658
3,036
Globecar
I have one of these, copied from an earlier post but the same as ours.
I wondered if the pole would come out to do what you have done except the hole is there, we dont use the AERIAL
Techno
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
That's not posted by me and nothing to do with my install so I cannot help you with your question.
EDIT oh yes I see your point. Yes the item I made is the same 36mm diameter so will fit your roof grommet
Welsh girl
3,658
3,036
Globecar
ok, thanks anyway, it wasn't posted by you, I copied it to show you what ours was like.
Sep 3, 2009
1,532
6,282
NW Surrey
LHD Hymer exsis-i
That was mine, it involves cutting off the RJ45 plug and fitting a new one once the cable is inside the van. We still use the TV aeriel, but if you don't then Andy's method is probably a lot simpler.
BTW if anyone uses the Motorhome WiFi antenna as I have, according to Adam it isn't meant to be outdoors permanantly. Mine has a liberal appication of silicone on all joins and seals, including tha RJ45 inlet.
Malcolm
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
View attachment 48011I have one of these, copied from an earlier post but the same as ours.
I have the iBoost as you see in the photo. I have ordered the mount to drill hole in roof ( already done in photo ) all I have to do is get the tubing ordered and I will start the fitting ( my photo's of install will follow.
Pudsey Bear
80
45
Keighley, West Yorkshire
Hmm, Seems like Andy has the very last one on the planet, I've searched for something similar, and only found some very inferior looking stuff.
Ho Hum, I need to find a solution, preferably cheap, shame I'm not into electronics, I'd make one and pop it into a IP67 or better box.
simbadog
1,683
3,337
Wengen
A/S Broadway EL 2021
Interesting (y) Like that idea, but are we saying that there isn't currently a similarish unit on the market?
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
You can use any unit that has a compatible hub.
The panel antenna that I use is no longer available new.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Don Quixote
2,966
5,258
VW T6 Campervan
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
I'm going to mount it like yours on the outside through the roof.
If you do, remember: ....
Malcolm
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
So much time and so little to do.
Today I fitted a Yale wireless security system, did the dishes, made the bed and finished my spare mast/panel
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I have one of these too. Are you in a position to compare with the latest Antenna sold by Adam ? I'm thinking of upgrading but do not see the point unless the improvement is significant.
I may be trialling a new offering from Adam in the near future (y)
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I know you have the tube ;) how's it coming on?
Floydster
1,071
2,766
Where ever I lay my hat
A lifetime
Hi Andy
We've got the same alarm system, works well, if you haven't already got them we can highly recommend the key fobs for this system, saves having to set/unset using the main box.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Hi Andy
I got a remote keypad , arrived today.
I got the alarm for £216 delivered (Amazon), over £300 at Screwfix
EDIT my old wired alarm gave 21 yrs service, not worth fixing given modern technology
Don Quixote
2,966
5,258
VW T6 Campervan
Andy, done nothing yet as had to sort family out so MH has taken back seat for now and need to get end caps for the tube. Cannot thank you enough for helping me out by posting the tube. I'm sure we will cross at some MHF meet and I will get the beers in.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I believe I have found a strong advantage with my panel antenna. Here at Ferry meadows CC I've had a reasonably good share of site wifi and it has been average to slow BUT! now it is absolutely pi**ing down following some snow and whilst everyone else has a weaker connection I am getting a BIGGER share of the bandwidth and it is now REALLY FAST :xrofl:
That's my theory
Every post is now lightning fast including this edit!
Don Quixote
2,966
5,258
VW T6 Campervan
Update:
Thanks to Andy for posting the tube to me I have now this afternoon made a start to fitting my "through the roof" wifi system. I will update over the next few days, but here are some pictures:
Tube with home made end caps and the Active Wifi antenna:
Might have tomorrow off so next update 2 January.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
I have the same one, (earlier one pictured) its neither robust or waterproof but works well.. just open Heki skylight and pop it on roof.
Don Quixote
2,966
5,258
VW T6 Campervan
The whole idea is not to have to open skylights or climb over seats to get the thing outside and cable trailing across things. The one I have is fully sealed by me so waterproof and as far as robust I don't think it will be a problem.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Don't we know it John :xThumb:
I'm nice n cosy inside in all weathers while my little buddy sits out there doing all the work :xgrin: No open skylights! no going outside
Don Quixote
2,966
5,258
VW T6 Campervan
Update2:
Photo's below of finished external wifi. I have not tested it fully as parked up in garage, however seeing about 6 more signals when fully extended. Total cost for parts about 37 quid ( thank you again Andy ) and total time to complete about 90 minutes.
The worrying bit drilling the hole...........
Was surprised how easy it was to cut through......
And from inside cupboard
Now the sticky stuff
And screwed on inside the cupboard
View of post nested
View of post extended - the yellow arrow is to show wifi is facing forward for travel
View from outside nested position for travel.
And extended to full height, however I don't think I will need to extend it fully most of the time.
Reach the limit of up loading pictures so Part 3 to follow.
Don Quixote
2,966
5,258
VW T6 Campervan
Part 3
Another view of extended
Nested view from skylight
Now we have no ware, cables or anything showing dangling across seats, windows or coming through doors of windows. Wife is so please.........
I would like to thank Andy for his idea.
