DIY Solar Panels - Making my own.
Discussion in 'Tech/Mech General' started by Gromett, May 9, 2011.
  1. Gromett
    Gromett Funster
    Feb 27, 2011
    8,349
    15,815
    UK
    I have made a start on making my own solar panel at last.
    I cut all the tabbing wires tonight which took longer than the soldering did.
    I then tabbed all the cells which was a lot easier than I expected.
    Tomorrow I have to assemble the aluminium frame and buy the glass.
    After that the hard bit which is connecting all the strings and doing the EVA encapsulation.
    I will do a full write up with photo's after I finish. It's proving to be an interesting project so far and I hope I will have a 144Watt panel by the time I am finished.:BigGrin:
    • Like it Like it x 7
  2. Jim
    Jim Ringleader
    Jul 19, 2007
    27,004
    79,557
    Sutton on Sea
    Sounds great. Any idea what all the component parts will cost Karl?
  3. Gromett
    Gromett Funster
    Feb 27, 2011
    8,349
    15,815
    UK
    Hot air gun £14
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110653551224
    Soldering Iron (needed a better one) £12
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280622969508
    Aluminium Frame £35.00
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280652721602
    Solar Cell, Tabbing Wire, Flux Pen and Diode £70
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270734053466
    EVA Encapsulation Film £10.35
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260771335777
    MPPT Charger £58.50
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270725736200
    All I have to buy now is cable and Glass. I guess £25 for the rest.
    So about £140 for the panel parts plus tools and carriage for each item.
    I need this one fast so it is going to be ugly as sin. If it works ok the next one I make I will construct a vacuum system to give a better finish.
    • Like it Like it x 2
  4. hilldweller
    Dec 5, 2008
    27,885
    26,962
    Macclesfield
    Were the cells as good as you hoped ?
  5. Gromett
    Gromett Funster
    Feb 27, 2011
    8,349
    15,815
    UK
    Much better. The defects are really really small.
  6. 1948
    1948 Read Only Funster
    Dec 3, 2009
    444
    46
    surrey
    Look forward to reading it in due course
    good wishes to the project
  7. 1Oll
    1Oll Read Only Funster
    Jan 12, 2010
    175
    86
    Cheshire
    Have Vacuum Press.
    Hi, I have a large heated (or not). Vacuum press made by Hotpress. We use it for laminating photographs. Based in Macclesfield 5 mins from Hilldweller. What is the thickness and dimensions of the panel for laminating. If it will fit you are welcome to give it a try.
    Regards Brian.
  8. Gromett
    Gromett Funster
    Feb 27, 2011
    8,349
    15,815
    UK
    It's about 1mtr by 1mtr. Probably a little large but thanks for the offer :BigGrin:
  9. Terry
    Terry Funster
    Dec 27, 2007
    10,808
    6,321
    South yorks
    Hi Karl keep us posted on this please
    terry
    have you any plans etc, for making one ? I may have a go myself :Eeek:
  10. Gromett
    Gromett Funster
    Feb 27, 2011
    8,349
    15,815
    UK
    I have started. If I can get the glass today I will finish it today as well I think.
    Karl
  11. samany
    samany Read Only Funster
    Sep 3, 2009
    103
    cheltenham, glos
    How do you guys know all this stuff, I am in the wrong job:cry:
  12. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,898
    6,157
    Mansfield,Notts
    Your too busy traveling and playing tennis:Doh:
  13. Terry
    Terry Funster
    Dec 27, 2007
    10,808
    6,321
    South yorks
    Hi Karl go to your local double glazing unit makers :thumb: make sure they give you normal glass and not the solar reflective stuff :Wink:Also if you are using toughened it will take 3 - 4 days to order
    terry
    EDIT they may know of a ali d/g firm that can supply the framing for you or if lucky there skip may have some old secondary glazing panels in it-always worth a look
  14. 1Oll
    Jan 12, 2010
    175
    86
    Cheshire
    It's in inches!
    Vacuum press size 67inches x 41 inches!
  15. Gromett
    Gromett Funster
    Feb 27, 2011
    8,349
    15,815
    UK
    I have found a glass supplier. The glass ideally should be low iron solar glass. This will cost me almost £40 + VAT :(
    41 inches is 104cm. Is that an internal measurement by any chance? I am tempted to take you up on the offer, you are quite a way away from me and it will take 3 hours to get there and 3 to get back plus diesel. I can't make up the strings until I am ready to bond them and I think that will take a few hours so it will be a long day :Doh: How much do you charge?
    Karl
  16. hilldweller
    Dec 5, 2008
    27,885
    26,962
    Macclesfield
    It all looked so simple. £70 for the cells to make a 140W panel. Let's go.
    I was tempted. But it's not looking good cost wise right now.
    I saw something like £1900 for 10 off 100W panels somewhere, that might be the way to go. Bryan style !
  17. Gromett
    Gromett Funster
    Feb 27, 2011
    8,349
    15,815
    UK
    Yup, it's starting to look a bit marginal on the costs front.
    However I am sure I can get the glass price down or just use normal glass which will be about £10.
    I think it's still possible to do 140 Watt for around £160 which using the wrong glass will lose about 5-7% so say its £160 for 120 watt still comes out quite good in comparison to premade ones.
    If I were starting from scratch again I would probably just go for the premade 80Watt @ £149 and buy one each time I had enough cash. However if I wasn't a full timer and had my workshop again I would make a vacuum machine and make a bunch of these panels. My big problem is not enough space in the van to store while I wait for the glass to be delivered.
  18. Terry
    Terry Funster
    Dec 27, 2007
    10,808
    6,321
    South yorks
    Hi Karl, I know next to nowt about solar panels :Rofl1: are the photo cells sandwiched in between to panes of glass or stuck onto a single sheet ?I had a large-ish panel-4ft x 2 ft- about 5 yrs ago ,and if memory is right it was in between 2 sheets.Anyway we had a think about putting it on the van and ended up smashing it in the bin :Doh::BigGrin:If it is in between 2 sheets then the price of glass is approx 20 quid per sq mtr (£10 per sheet) or if you wanted solar glass- that has a coating on to reflect heat that works out at 27 ish per sq mtr-- If you used 1Oll vacuum press I assume that is like a big laminater would that allow you to roll it up and fix it on a curved surface?
    terry
  19. Gromett
    Gromett Funster
    Feb 27, 2011
    8,349
    15,815
    UK
    Hmmm, Not going so well on getting the glass. I have been told that I would need 6mm Tempered glass.
    The low iron glass costs £80 :Eeek:
    Normal glass will cost me anywhere between £66 - £80.
    Reading this http://www.solarpaneltalk.com/showthread.php?2230-Cost-analysis-of-glass-types There is only 5% difference in the efficiency so I won't be going low iron.
    I am now looking at polycarb/plexiglass etc. Tempered glass will shatter and destroy the panel if caught by a tree.
    Grrr. This is getting complex and potentially expensive :Doh:
    Karl
  20. hilldweller
    Dec 5, 2008
    27,885
    26,962
    Macclesfield
    I've got that tee-shirt !!
