Distracted by grandchild
Discussion in 'Tech/Mech General' started by MAUBRI, Aug 30, 2010.
  1. MAUBRI
    MAUBRI Funster
    Aug 9, 2008
    196
    4
    Lanner - Cornwall
    Please !! Please dont do what I did a couple of weeks ago, Putting the Toad on the back( with help of grandchild) before going off on a short break to Bournemouth, checked breakaway cable/Electrics/pumped the brake/connected bungy under seat to Brake pedal/checked gear stick in neutral, took keys out of ignition and locked up.:BigGrin:[ I used to have a SMARTY but now have a Toyota Yaris Verso.] Drove to the bottom of the hill and turned left approx 300 yards futher on came to roundabout and took 3rd exit BANG!! LOOKED IN REAR CAMERA TO SEE "A-FRAME" BENT DOWN TO FLOOR LEVEL ON ONE SIDE. Pulled over and then looked at front of car eeeeeeeek:cry::cry:
    As you may have realised by now I HAD TAKEN THE KEYS OUT OF THE IGNITION AND LEFT THE STEERING LOCK ON. Modern cars do not like being pulled sideways against the wheels.
    I now have a crumpled underneath bodywork,enough to push the bonnet up by 2 ins, luckily no components were damagaged; it could have been worse but I had reinforced the underneath towing framework with two 3mm angle iron bars back to the transmission subframe. The front flat 5mm bar connected to the 1 1/2" Diameter towing bar had bent down on the right hand side back to the fixing bolts.
    So basicaly I now have no current Toad, so its taxi or hire car for a while.:Blush:
    Have fun and please tell the Grandchildren to get in the RV before hitching up, its cheaper on the wallet.
    BRIAN
  2. tick59
    tick59 Funster
    Dec 25, 2007
    1,254
    1,110
    Newcastle Upon Tyne
    OOOOH!!!! PAINFUL:Doh::Doh:
  3. Landy lover
    Landy lover Funster
    Jul 11, 2009
    2,066
    4,369
    Zummerzet
    Bad luck Brian - is it repairable ??
  4. movan
    movan Funster Life Member
    Dec 2, 2009
    13,950
    25,373
    Moving around
    Yikes!!!! I can imagine what you felt when you heard that noise!!!!!:cry:
  5. MAUBRI
    MAUBRI Funster
    Aug 9, 2008
    196
    4
    Lanner - Cornwall
    Sort of but not perfect without a new load of panels, I've pulled out and straightened most, luckily it wasn't a problem with the MOT. There was no damage to the top Bodywork/Panels
    Brian
  6. frogijock
    frogijock Funster
    Jul 3, 2008
    710
    408
    Lincolnshire
    Have you still got the grandkids? or have they been disposed with :thumb:
  7. laneside
    laneside Funster
    Aug 14, 2009
    3,577
    5,599
    Oradour sur Vayres
    laneside
    Well just fancy , poor grandchild takes the blame.
    We just hate admitting to senile dementure don't we.
    Aks the Missus for an honest opinion, she will tell you its been creeping in for years
    Alan
