Dell Inspiron re-set (1 Viewer)
Oct 7, 2013
5,894
36,912
South Wales
Swift Escape Compact
Since 1988
I have a Dell Inspiron N5110 laptop that has been running very sluggishly.
Having done everything I can to improve matters, cleaning the disc, cleaning the registry and defragging etc I want to start again and reset to factory settings.
According to the instructions i should
Press the power button
Hit F8 repeatedly when the Dell logo appears and before the Windows logo appears.
This should take me into an "advanced boot" menu.
I should highlight " repair my computer" which will take to another menu where I can select "return to Dell factory settings" or similar words.
Now
I can get as far as highlighting "repair my computer" but, on hitting "return", Windows starts up normally and I cannot reach the reset option.
Am I doing something wrong?
Help!,
Jul 13, 2008
3,739
3,863
Low profile
Do you have the original Dell installation DVD?
crabman
336
188
Anglesey Wales
just looking
newbie
try tapping f8 or f7 to get to out of box reset, on my old one is says tap F2 turned out to be F8,
TheBig1
17,630
43,277
all well and good doing a factory reset but it will give you an outdated version of windows needing multiple updates
R
Robert Clark
I had a Dell Inspiron laptop which had issues caused by AVG anti virus software
It improved massively after removing it
Also it's worth vacuuming any dust from the vents underneath
maison
Oct 7, 2013
5,894
36,912
South Wales
Since 1988
Yes. Appreciated. But it is virtually unusable at present.
Although I have run virus checkers, malware removers etc. It is still slower than our old netbook despite having an i5 processor.
R
Robert Clark
Have you tried a decent registry cleaner ?
I've used this one
Broken Link Removed
43,329
49,444
Same with Norton if its an older version.
Can suck resources faster than yer granny can suck eggs.
Vanman
1,665
3,916
Runcorn
Roadscout R PVC
March 2017
Usually with Dells there is a restore partition. Depending on your security levels etc you may be able to see it in Explorer/file manager, it'll say something like RECOVERY (D: ) If it's not there then the restore won't work and it will default back to boot Windows. ASC (Advanced System Care) do a free version that can fix a variety of issues.
maison
Oct 7, 2013
5,894
36,912
South Wales
Since 1988
I've used this one
Broken Link Removed
I have run Eusing Registry Cleaner regularly.
I am currently removing progs I no longer use. However, I still feel I would like to make a hard reset, but still no luck getting past the first menu.
maison
Oct 7, 2013
5,894
36,912
South Wales
Since 1988
Can you expand on ASC?
I have a reluctance to rely on third party fixes but will now try anything that might work.
maison
Oct 7, 2013
5,894
36,912
South Wales
Since 1988
@Vanman
I am not trying to restore but to make a hard reset. The restore function, while it works to restore the computer to a previous time, does not cure the problem.
Sorry if I have misunderstood your post.
mid4did
526
728
N.somerset
Hymer Tramp R 655 GT
started in a minivan 1970's when I could fit into it.
Did you actually create the restore dvd,s if not can you still do that via the create recovery dvd programme? If you want a quick fix try running msconfig at the run command, just type in msconfig and enter.Under services check hide all microsoft services then click disable all under startup click disable all then apply and do a reboot.
maison
Oct 7, 2013
5,894
36,912
South Wales
Since 1988
I have some old restore DVDs .
When you say "a quick fix" what is the purpose of your suggestion?
Sorry! I have reached the limit of my understanding at present.
Vanman
1,665
3,916
Runcorn
Roadscout R PVC
March 2017
@Vanman
No, you didn't misunderstand but perhaps mine was poorly worded. I meant restore to factory settings. I would not recommend that most of the time anyway as the original drivers etc may not work with your current hardware set-up. As an interim solution you could try reinstalling Windows, that cures a lot of problems but you do need to have all your software disks and keys to re-install them afterwards (assuming you have a valid copy of Windows) always worth having one even if Windows is pre-installed.
However what I would do first is download this software and see if it can find and resolve your issues for you.
Advanced Systemcare
mid4did
526
728
N.somerset
Msconfig will let you stop unwanted programmes running on startup amongst other things.What I,m suggesting is to disable programmes that are hogging your resources.This method usually gives you a faster bootup.Also empty your recycle bin and check you have plenty of hard drive free space .
maison
Oct 7, 2013
5,894
36,912
South Wales
Since 1988
Reactions: DBK
crabman
336
188
Anglesey Wales
just looking
newbie
do you have skype, if so a tech will sort it out for £30 did my brothers the other day after windows corrupted all the files on a update, here the number 08006524940, don't pay anymore they want to try and get £100 out of you say no I will buy another laptop, thas what they did to my brother, I told him don't fall for that old con
crabman
336
188
Anglesey Wales
just looking
newbie
correction its AVG internet security, but give them a ring a tech may well sort it for you
maison
Oct 7, 2013
5,894
36,912
South Wales
Since 1988
@Vanman
Have now downloaded Advanced System Care and will run it tomorrow after I have slept on the problem.
Thanks.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
If you have (or can acquire) a Windows OS disk why not simply format the HDD then reinstall? That guarantees a fresh start.
maison
Oct 7, 2013
5,894
36,912
South Wales
Since 1988
That is what I am beginning to think will be the best option.
I am also looking through all my DVDs for any disc that may help.
After moving house they are still to be properly unpacked.(n)
Thanks.
Feb 27, 2011
14,737
75,976
UK
Self Build
If the restore partition is gone then you will have the problem you are experiencing.
My recommendation is that you download a fresh windows ISO and install from that.
You don't mention which version of windows so I am guessing windows 7?
https://www.microsoft.com/en-gb/software-download/windows7
If you are not on windows 7 let me know and I will link to the download.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
Good option. I forgot that ISOs are readily available.
maison
Oct 7, 2013
5,894
36,912
South Wales
Since 1988
OK. I give up!:mad:
I have now removed virtually all the progs. on my hard drive. I can't find my "rescue" disc after moving home.
The PC is now usable but I think I have found the problem. I have one program that will not uninstall. Attempting to do so with M/S uninstall, Revo Uninstall and (10?) uninstall all lead to it opening multiple "install" windows. The only way to stop it is to do a forced close down. Task manager cannot control it.
Unless anyone has any ideas for a " super uninstaller" I will have to live with it.(n)
The suggestion by @Baileysbus for a keyboard for my iPad may be my favoured route.
Many thanks to all who have tried to help. I appreciate it!
However, life is too short to waste too much time on what is a minor problem in the whole scheme of things. (I lost my Mum two weeks ago).
Once again, thanks all.(y)
