Dehumidifier issues (1 Viewer)
Norm
168
54
Lower Froyle, Alton, Hampshire Surrey borders
Since March 2014
After a first 4 week tour in May I parked my new Burstner on the drive, emptied fresh and grey water tanks leaving taps open, gave a general clean and placed the dehumidifier inside to dry out any remaining condensation.
Over the last 6 weeks I have been emptying as much as a litre of water every 3 days and it hasn't stopped yet!! No sign of damp anywhere. It's a mystery!!
Any ideas anyone ??
2,387
10,394
get rid of the dehumidifier.. it's sucking damp in from outside..
if the van is damp the source needs to be found and repaired.. I never have damp and have never used a dehumidifier.. just ventilation.
32,695
66,724
... basically what Jim said!
Dehumidifiers in MHs are just NOT needed unless there is a problem already and you need to dry it out due to that. There is no reason at all to use them in a MH normally ... in fact IMV they actually encourage more damp air to enter the MH in the first place to replace what has been sucked out!
18,041
48,179
It may also be sucking moisture out of any wood to the extent the wood may shrink and crack. You can certainly use a dehumidifier, plenty do, just be careful and not overdo it.
A litre every three days is nothing I think. You don't have a damp problem and it's either coming out of the wood, which has a natural moisture content or from outside air as suggested.
53,648
150,781
No point in using a dehumidifier in a Motorhome unless you block off all permanent vetilation . As others have said you are just trying to dry out the atmosphere.
32,695
66,724
Well that's a relief. That all makes good sense. To be sucking it in. Now switched off and removed.
Thanks Guys.
Good to know you're no longer a 'sucker'! :D
