Database empty !!!!! (1 Viewer)
Mar 24, 2010
1,073
765
stoke on trent
relay lwb pvc
6 years
Have had a MEOS 15.4 12v TV given to me back that hasn't been used for a few years. DVD works OK but however I try cannot get it to pick up any channels-keeps coming up with "database empty" .Had the house aerial on to check if it was that but same problem.If I set it to search it will go through the system and come up with !database empty" .Could it be that it is not DTV suitable?
43,334
49,533
Connect to house aerial to ensure you will get a signal.
Open the onscreen menu,
go to SOURCE, (or if there's a 'source' button press it)
select DTV,
retune.
Chances are its defaulted to Analogue signal but if that fails the tuners buggered..... Bin it.
Chris51
Mar 24, 2010
1,073
765
stoke on trent
relay lwb pvc
6 years
Tried that but same ending-worth a try though-thanks Chris.
tonka
10,834
21,544
Cannock, Staffs
A class Burstner 800
Since 2000
Check if there is a factory reset within the menu.
If so use that and then do a fresh re-scan...
Worth a shot as seen this problem mentioned a few times..
Chris51
Mar 24, 2010
1,073
765
stoke on trent
relay lwb pvc
6 years
Have reset it a couple of times but no joy .Thanks for looking at my other TV much appreciated. Going to get a new one. Reguards Chris.
tonka
10,834
21,544
Cannock, Staffs
Since 2000
The web seems to be full of people asking about this problem but no real answers.. :(
Lenny HB
53,489
150,258
On the coast in West Sussex
Hymer B678 DL
Don't do EHU so only 12v for digibox.
The small ones on ebay & Amazon are often 12v with a seperate power supply I've got a Bush one at home that's 12v. Otherwise they will run off a small plug in inverter they don't use much power.
Chris51
Mar 24, 2010
1,073
765
stoke on trent
relay lwb pvc
6 years
Been looking on E-bay etc for "12v digibox" but seem all to need a sat dish . I bought a TEVION sat dish set from ALDI a while ago that I never used. Perhaps a numpty question but suppose it can be adapted to use with an aerial instead of sat/dish?
SandraL
1,373
985
Somerset
Hymer b694sl
Try searching for
Dvb t2
Digital video broadcast terestrial version 2
About £15 on ebay, most have plug top converter power supply but dont usually mention dc voltage it outputs, ask seller the question.
Eg.
Chris51
Mar 24, 2010
1,073
765
stoke on trent
relay lwb pvc
6 years
Try searching for
Dvb t2
Eg.
Have e-mailed supplier for info as need to be compatable with 12v supply (off grid).Thanks Chris.
43,334
49,533
No it can't Chris.
You specifically need a 12v FREEVIEW TV digital RECEIVER.
FREESAT and FREE TO AIR receivers are satellite digiboxs
