Dash Cam power wire routing (1 Viewer)
GeriatricWanderer
1,194
4,199
Ouagadougou, Burkina Faso, just cos I can!
Pop-Top Campervan
45years
I'll shortly be moving my trusty dash cam from one vehicle to another and once again I'll have to fiddle and faff trying to find the best route and the tidiest way of running the power wire from the camera, located close to the rear view mirror, to the cigar lighter socket on the dash.
It's no big deal - I usually run it across the top of the windscreen/sun visor fixing, down the side of the windscreen and then across, or under the dash. Copious amounts of tapes keep the wire more or less in place but this time I'd like to find a tidier way of fixing the wire.
There must be some clever little fixing gizmo out there to make a better looking job of the task - Velcro/self-adhesive clips? but I can't find them.
All ideas gratefully received (except those suggesting hard wiring).
Cal54
3,806
62,034
Southport, UK
Leisuredrive Renoir
Since 1996
There are some clips available from Road Pro which are classed as self adhesive cable ties, these might be the type of thing you are looking for. I bought a pack at one of the outdoor shows for just this purpose. I since found them in Halfords and bought another packet.
Sorry don't have the techy ability to post the link!
GeriatricWanderer
GeriatricWanderer
1,194
4,199
Pop-Top Campervan
45years
Thanks Carol - I never thought of Halfords.
I've seen something on Ebay that might do the job but difficult to judge from the picture.
I'll be back home next month so will take a trip to our local Halfords and see what they look like close up.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
G-W. I know you where against "Hard wiring" but where is the power to your cab interior light?. Some are just over the rear view Mirror?.
BTW, why DO they leave rear view mirrors in motor-homes without a rear "View"????? I can see the the Toilet door but that's about ALL!!!!
Pete
golly
2,006
69,617
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
I managed to tuck the cable into the head lining and behind the trim of the window pillar. Where that wasn't possible I used these Broken Link Removed
Lenny HB
53,443
150,049
On the coast in West Sussex
Hymer B678 DL
I fitted mine at the side of the screen as they are a wide angle lens position is not criticle. Ran the cable down the side pillar and brought a USB power supply which I fitted under the dash connected to the radio feed so it comes on with the ignition.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Me too. Can't do with trailing wires & plugs.
GJH
29,450
38,827
None, now sold
2006 to 2022
This is how I have the dash cam mounted in the van. It is plugged into an adapter which is also used for the sat nav. The cables for both are looped in the shelf with a piece of non-slip mat on top which is light but heavy enough to keep them in place.
Lenny HB
53,443
150,049
Hymer B678 DL
Same here, also splashed out on a double din stereo with satnav & the reversing camera feed into it, no flying leads at all on my dash, even a USB lead for phone charging I fitted inside top glove box.
