Cutting hole in van (1 Viewer)
Jamwitt
630
367
Chandlersford
C class
4yrs
:rolleyes:Hi I need to put a 60 mm hole in van for BBQ point with a hole saw but a bit worried as aluminium sandwich construction what type of saw ,I guess it should be a fine toothed saw and where could I get one !
Dazzlin
1,751
6,213
La Marina, Costa Blanca.
1986 Hymer A Class
From 2013
I just used a standard holesaw.
1 x 20mm pump plug
1 x 70mm gaslow
1 x 90mm bbq point
Just measure twice and go slow.
Apr 19, 2008
1,942
2,921
Kent coast Hythe
Rapido fiat based
brought first van 16 yrs ago
try this
images
Jul 5, 2013
11,731
13,708
Since 2013
Buy one from Toolstation or screwfix. Don't bother with the multi-size ones - they are awful and often not deep enough. Instead get the correct size one and an arbour to hold it, Toolstation are cheaper than screwfix, When I was drilling hole through the roof for solar I got a 29mm one and arbour for about £3 from memory.
Badknee
7,408
412,826
notloB
Vantage Neo
Living the dream.
When the pilot drill has gone through don't put much pressure on the holesaw as it might bite and the pilot drill may move out of line because the skin is so thin, gently gently. If your really worried practice on a piece of scrap ally.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Run the saw at full speed but feed it in slowly. The saws are not intended to operate at low speed & to do so will cause it to grab. If you are nervous drill the pilot hole first with a conventional bit then the bit in the holesaw only acts as a guide.
Jul 5, 2013
11,731
13,708
Since 2013
Since this is a sandwich construction wall the holesaw should not move off of line much once it is through the outer skin. However to make a neat job on both sides I suggest you first drill through one skin and into the sandwich insulation. Then drill from the other side, using the pilot hole that has come through as a guide.
In my experience you will not need much pressure to get through either skin, and certainly not through the insulation. Just push gently with the drill on high speed.
winchester
13
11
abermule powys
c class
since 1998
Got the hole saws from travois Perkins and did the electric and bbq point in about an hour fitted, but remember gas must be checked after,DAVE newel did my check
Jul 5, 2013
11,731
13,708
Since 2013
60mm does not appear to be a standard size. Toolstation will sell you a 57mm or 64mm one, and one of those, with the correct arbour, will cost you between £9 and £10 depending upon what size you go for. On the other hand you can buy from them a set of 7 sizes, including the 64mm one and including the arbour for £5.84!
43,331
49,467
hole saws are designed to work at an appropriate speed for saw size and material being cut
if you buy quality (starett etc) instead of cheap rubbish there is a leaflet with the saw giving recommended speeds for various materials and saw sizes.
from memory a 100mm saw has a max recommended speed of around 600rpm whereas a 15mm could be as high as 1800rpm.
tambo
874
639
Dunfermline fife scotland
a class
MH Since 2008, ex tugger and vw campers since 1992
Lot of over complicating on this lol
I use these daily .....buy a hole saw mark the hole and drill it .....honestly it isn't hard the aluminium is only 1.2mm thick then polystyrene followed by 4mm board
If it's a new hole saw you'll hardly notice it cutting it will be so quick
You should have had it done by now :p
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Most vans are only 0.6 mm :)yours must be posh to be double thickness --mines 1,5 mm ali but on the roof it's now 3 mm :D
terry
tambo
874
639
a class
Most vans ? Or British vans lol
Mine is 1.2 or 1.5 I never measured it to be honest but had all windows out the other day
Think the roofs thicker as I can walk on it without probs .......but I don't think he's fitting the bbq point in the roof :)
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
Agreed but the speeds recommended are for continuous cutting - in other words with enough pressure on the saw to maintain continuous cutting and to keep the teeth cool. Doesn't really apply to a millimetre of aluminium - foam (effectively nothing) - 3 or 4mm of plywood.:)
43,331
49,467
agreed, never thought of that when i replied
