cree torch (2 Viewers)
Feb 27, 2011
14,741
76,018
UK
Self Build
I am not sure if you guys know but Cree is the manufacturer of the LEDs not the torch itself. Now all things being equal. A cheap "Cree based" torch using a single AA battery will produce exactly the same amount of light as an expensive "Cree based" torch using a single AA battery.
The one I linked has a solid Aluminium body, a big chunk of glass for a lense and a Cree LED. I was stunned by the power output and it fits in the front pocket of my jeans. I ended up giving my £30 rechargeable cree based Torch to my Brother In law. That one used an 18650 battery and to be honest I couldn't tell the difference in brightness for my uses. The el Cheapo fits in my jeans pocket which the 18650 one wouldn't. And I was forever forgetting to put it on charge. With the little one I just swap the battery. The only thing I could think of that would make me upgrade is if I needed a fully water proof one.
The Cree website is here.
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Yes Karl well aware Cree make the leds :xThumb: and if you compare the same torch powered by a AA battery, then with the 14500 rechargeable 3.7v one it is soooo much brighter :xThumb:the same happens with the 3 x AAA ones then stick in the 18650 battery -again (as you know) what is a very bright torch becomes even brighter :xThumb:
What I don't understand properly is the mere fact that the LEDS on some torches will work on 1.5 v yet work on 3.7 v (brighter) then some will only work on 1.5 v -and some only on 3.7v-Hence my warnings on earlier posts of been careful on what you order :xeek:
I bought 10 that only work on the 3/7 v and I still have 3 that I don't yet have batteries and charger to fit :xdoh:These are the small green/red and blue ones :)
terry
iandsm
Jan 3, 2008
3,341
5,359
Pakefield, Lowestoft, Suffolk, UK
Looking
Just to update as a matter of courtesy, I ended up buying the Led Lenser P7.2 on Amazon @ £36.00. It is very compact and fits easily in a pocket, There is obvious quality to the manufacturing and it seems to be made out of top grade Parts. It is VERY bright when on full and even on low power makes my previous three cell magnet look poor. The adjustable focus really is a bonus because it goes from a spot to wide beam just by using one hand so finding a runaway dog on the beach should be easy. All in all a good piece of kit for the motorhome and general use which very much exceeds my expectations.
MattR
4,105
38,894
Beds
Panel van
Years
Glad that you like it. The quality of Lensers is great.
