Couldn't get gears after not using for while
Discussion in 'Motorhome Chat' started by solitaire woman, Apr 13, 2010.
  1. solitaire woman
    solitaire woman Read Only Funster
    Apr 27, 2008
    78
    Am sure I read something similar a while ago but I have done my best to search and just can't find it, so sorry, but have had to post again!
    Went to get my motorhome out of storage today and could not get any gears at all. Tried several times with the engine running but could not get any gears. After leaving it for a while I went back with my son who tried the gears whilst the engine was off and found that after a while he could get the van into gear. We tried again with the engine on, at first we still couldn't get any gears but after a few attempts we managed to get the gears to work.
    I am going back tomorrow to take it for a run but am worried that this problem will occur again. I am not sure what caused this problem, do you think that it was just a one off, or is there a undiagnosed problem which I need to have checked out at a garage? Hope someone may be able to help. Thanks.
  2. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,815
    13,725
    Norfolk
    Sounds to me like as a result of being laid up the clutch was frozen and not clearing the flywheel when depressing the pedal. Now its free should not be a problem.
  3. Madmike
    Madmike Read Only Funster
    Apr 12, 2010
    15
    Pickering
    Hi Solitaire,
    Sometimes when a vehicle has been standing for a long time the clutch plate sticks to the flywheel thus making it impossible to engage a gear even when the clutch pedal is depressed. The fact that you warmed up the engine and eventually after depressing the clutch pedal a few times the plate came free and you are able to engage a gear now proves that the clutch plate is now acting as it should be. I would expect that you will have no further trouble as the flywheel will clean itself up with the normal use of the clutch. Should you have the same trouble again next year put it in gear depress the clutch pedal and then engage the starter motor having first made sure that the hand brake is firmly engaged.
    Hope this helps.
    The Mad One
  4. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Hi solitaire woman
    Agree with the above post, it is sometimes called sleepy van syndrome can happen to quite a few parts brakes, clutch etc, best way to avoid is to take for a brief run at least once a month possibly less while laid up.
    Hope this helps.
    Dave :thumb::thumb:
  5. maxsdad
    maxsdad Funster
    Oct 5, 2009
    298
    234
    anglesey
    sounds like clutch plate stuck to flywheel with standing,will be ok now its freed off,best to start engine every month or so and drive vehicle back wards and farwards a few times.
    dont leave standing on damp area ie grass or badly drained ground for long periods of time if it does stick again aply hand brake ,put in gear ,depress clutch and start engine should free it.
  6. solitaire woman
    Apr 27, 2008
    78
    Thanks for answering so quickly. I feel much better now that it seems it will have sorted itself out! Thanks again.
  7. Jim
    Jim Ringleader
    Jul 19, 2007
    26,430
    78,081
    Sutton on Sea
    All that help, advice and peace of mind, just a few clicks away.:Smile: Aren't forums great:thumb:
  8. yorkshirepudding
    yorkshirepudding Read Only Funster
    Nov 7, 2009
    1,221
    908
    Pudsey/Leeds
    This one certainly is.:thumb::thumb::thumb:.
