copy route to sat nav (1 Viewer)
ehuplad
504
93
North Yorkshire
Hobby 600
Hi all,
I want to copy a route from MS autoroute 2010 onto my Garmin Nuvi can it be done :RollEyes::RollEyes:
If so how, do i need some other software.:Smile:
Jaws
23,836
72,493
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Not sure that can be done direct, though I believe there is a converter available to shift from AXE to GPX format..
I personally use Garmin Mapsource to plan a route as it is directly compatible and directly uploadable to the garmin units
ehuplad
ehuplad
504
93
North Yorkshire
Hobby 600
Thanks Jaws autoroute allows you to save the route as a gpx just do not know where to put this file on the garmin or if it is possible.
Jaws
23,836
72,493
Thetford Norfolk
C class, Chieftain
Hmmmm
GPX files are more normally associated with Points of Interest ( POI's )
Routes are generally .GDB's I believe
But.... You could upload the GPX file and use the POI's to plot your route I guess ?
Plug the GPS in to a USB port
When it comes up you want to view files
Look in the Garmin folder and you will find a sub directory ( folder ) called GPX.
Upload you gpx file to that and it should find it in Points of interest.
