Converting fluorescent tube light to LED tube light (3 Viewers)
Jul 31, 2014
1,930
3,241
West Yorkshire
EuraMobil Activa 820HS
I've been reading through the many past posts relating to swapping out MR11 halogen bulbs for LED's and SMD type bulbs and wondered whether anyone has changed their fluorescent tube/strip light for an LED tube light?
(This isn't the LED strip light type of lighting which you cut down to length. It's the T5 fitting tube with the two prongs on each end - looks very similar to the tube currently fitted).
I've come across these tubes in some online stores (bedazzled lighting for instance) and although expensive, they last a lot longer and use less juice - apparently.
What it does say is that you have to remove or bypass the high voltage driver/ballast unit. Has anyone any experience of doing this?
Or has anyone changed their standard fit tube lights for LED tubes?
11,955
16,570
They look good to me. The original tube driver is easily removed leaving a simple 12v & earth feed to the unit. The instructions with the tube will explain how to connect the feed & earth to the tube.
Bobby22
1,537
6,408
Rapido 680ff
since 2013
Should soon be on ebay at a fraction of the cost...............might be worth waiting.
967
3,361
Yes, have done it.
As stated, use the 12v supply by bypassing the circuitry there. Straightforward really, and every little helps when saving the amps.
Jan 28, 2008
10,117
18,383
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
why use an expensive tube when you can just use the self adhesive strips mine are four years old now and going strong each fitting cost less than a fiver to convert and took 15 minutes to do if you anywhere near me i could help you do one
Dec 27, 2014
967
3,361
Exactly,
That's what I used in the tube fittings.
tonka
10,834
21,541
Cannock, Staffs
A class Burstner 800
Since 2000
As above..
I cannot see any benefit to buying tubes if they are a lot more expensive and you need to mess about disconnecting the Inverter.
If they are under cupboards you dont even see them.
On my previous van I removed the tubes, Found the 12v supply before it entered the ballast / inverter on the strip light.
Fitted adhesive LED strip under the cupboard and connected to the 12v.. Simple, effective, power saving etc..
Reactions: f6c
43,332
49,505
Agree with other re led tubes.
if the light has a cover its far cheaper to replace with a flexy led strip.
Bypassing the ballast is simple.
Make sure the 12v is turned off.....
cut both v+ and v- where they connect to the circuit board and connect to v+ and v- on the led strip.
remove the old board if needed.
All mine where twin tube with the board in the centre so i left mine in situ in case i ever had to revert to fluorescent tubes.
53,476
150,187
Agree the power saving will be minimal at best may even be worse, also florescent's give a more even spread of light with softer shadows.
GAVLAD
Jul 31, 2014
1,930
3,241
West Yorkshire
Great advice everyone and thank you all.
It's given me food for thought.
I'm in the process of changing the MR11 bulbs, so will have a look at the tube situation next.
Thanks again.
43,332
49,505
An average 12" 12v strip light (flourecent) is 11watts......an LED strip of the same output is around 2watts.
an 80% saving.
I replaced 9 x twin tube for single led strips
all 18 tubes together consumed around around 16amps...i can run all 9 leds for the same as one twin tube light.
andreWander
8
7
Thames Valley
Knaus Sun Ti 2007
Ditto. remove tube and disconnect feed. Wire led strip instead. I had two lights on same switch. great saving.
53,476
150,187
an 80% saving.
Does depend on the LED you use and if you have that amount of tubes worthwhile, but most vans usually only have one tube above the hob. Well that's in all the vans I've seen and it's only on for a short time while cooking, that was my reasoning.
Jan 28, 2008
10,117
18,383
Renalt burstner
Ditto. remove tube and disconnect feed. Wire led strip instead. I had two lights on same switch. great saving. View attachment 54938 View attachment 54939
ours were quite short and we wanted them for reading so we went up and down the fitting four timesstuck down along the straight runs and just curved of the surface at each ends
43,332
49,505
Agreed....just one or two may not be worth the money and time.
I didnt change the twin tube light in the toilet for obvious reasons....you're only in there a couple of minutes whereas all the others are hab lights.
Feb 26, 2012
528
368
coach
Motorhome since 2006 (caravanning 38yrs)
How stable does the voltage need to be for these strips?
On another thread it was suggested that LED's need to be capable of several volts variation or will blow. I think it needs to be 10v - 14v to allow for use when on charge from mains hook-up.
43,332
49,505
Never had a problem with mine on genny, both onboard and suitcase, mains charger or solar.
Charger has an auto desulphating mode at 15v every 20 days or so...never caused a problem.
Jan 28, 2008
10,117
18,383
Renalt burstner
i think the leds used now are less sensitve to voltage my first ones failed very quickly they were the silicon encapsulated ones
Jan 11, 2010
2,749
9,583
Chester
Auto-trail
We agree with mitzimad, we changed all internal lighting for strip leds, having a "U" shaped lounge we bought a couple of 5 mtr Warm White lengths cut and soldered to length used them under and above the cupboards to create a really soft lighting effect.
Took a couple of hours to strip out the old fluorescent tubes and fit the new led strips, the new led system used around 80% less power.
celcat
22
11
2 years
I'm changing our lights this weekend and have found these
but now I'm slightly confused as how to fit them o_O
Please help!!
Jan 28, 2008
10,117
18,383
Renalt burstner
Please help!!
looking at that link they apear to be solid lengths rather than the rolls of led but principle will be the same im not sure if you can shorten those but it does say you can connect up to five basically stick them to the place you want them then two wires they are usually polarity sensitive to red to plus and black to earth
celcat
22
11
2 years
Thank you! Where can you get the rolls of LED? (Still googling!)
Bluestar
279
164
Brighton
Class
10 years.. On and Off
eBay, in the UK or cheap direct from China takes a couple of weeks.
O
Old Soldier
Hi.
I bought mine on eBay. I had already changed the older bulbs with LED but have now gone one step further by fitting LED RGB strips around the top of the van to create "mood" lighting. Works well. If Les is in a good mood I makes it all red or if I'm in the sh*t for something it's blue! I can adjust to most colours, depending on mood!
I also used white LED strips to run down the inner and leading edge of the awning. When the awning is rolled in, it provides a double light down the whole side of the van, if the awning is out then it provides an even light throughout the awning. As the light is adjustable in intensity I can keep it low or light up the whole bloody campsite!! They have been fitted for over a year and are still working well ( so far!) :winky:
Jun 19, 2014
41
26
Cardiff
Low Profile
I'm a newbie
Have done the two of mine in Chausson 85 tubes used 0.9 amps with led now 0.17 amps thats each light bought from internet at 70 pence per strip (plus postage from china ) used 2 per light nice color light .Does anybody want the old units with tubes free to good owner (will be at Peterborough on Fri ) to save on postage
