Controller error (1 Viewer)
Jan 13, 2013
34
76
Leicester
low profile
Hello currently at Peterborough show. This is not an urgent problem (yet).
We appear to have a problem with the solar charging.
The leisure batteries (1 in the pic) are ok and seem to have recovered from our usage so far. However battery 2 (starter battery) is showing blank.
The main panel is showing LB 13.5v and starter battery at 13v.
Over the winter when I have collect the Moho from storage the starter battery has been as low as 12v.
Any advice/pointers welcome.
Paul
Jan 8, 2013
8,490
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Check the starter battery connection in the controller.
Try unplugging the cat 5 cable from the controller for 10 minutes
Kannon Fodda
2,585
8,000
Seek and Ye May Find
Autotrail V-line 540
I Make Schoolboy Errors!
If there is charge going to a battery it's voltage is likely to read 13v or more. When you collect van from storage you are seeing the resting voltage which is the one of real issue, 12.6 -.7 being about full.12.0 being just under 50%.
Mar 14, 2020
658
514
Isle of Man
Autotrail Cheyenne
Since 2015, still learning
Can you put a multimeter on the starter battery? will it start?
sorry. Just realized this is from yesterday. Hope you got sorted
