Paul an Jane MK
- Apr 20, 2016
- 435
- 486
- Elddis Encore 255
- enjoyed the freedom over the last couple of years but still Wish we could have got away more often
Hi All,
A couple of weeks ago I bought portable 14 watt solar panel from Maplin which I left propped up on dashboard and connected to engine battery. The batteries were both at 12.2 volt.
I popped back yesterday to check the batteries and was pleased to find engine battery was actually 12.3 volt, okay nothing exciting but at least had been maintained and most days have been overcast and grey. However the leisure battery had dropped to 11.9 volt not so good and proves solar panel has done something.
I intend to get solar panels fitted to the roof very soon so do not want to buy another portable one so as a quick fix, I left the control panel turned on and pressed the button that connect the two batteries together at which point leisure went up to 12 volt and engine went down to 12.2 volt and hopefully leisure batt will benefit from solar panel as well.
Apart from leaving panel turned on which I would not normlly do (although everything else turned off in moho,) are there likely to be any ill affects from leaving them connected.
Your thoughts appreciated.
Paul
Paul
