confused,ignition lights on with main battery disconnected (1 Viewer)
cypsela
13
3
morecambe
fiat ducato 1996 hobby
im a newbie
hi can any one tell me should i still get ignition lights when i disconnect main battery,i presume the leisure battery is wired up to the same circuit,its a fiat ducato 1996,with a hobby tuscarna conversion,i now it recharges of the alternator,is it normal for this to happen or is something amiss with the wireing.
Oct 7, 2015
737
3,578
newark
Swift escape 624
Sound like the split charge relay is stuck or you are on mains hook up
43,331
49,466
Quite possibly the split charge relay has stuck closed or has been bypassed altogether....Can't think of any other way it can happen unless both batteries have been intentionally linked.
Oct 7, 2015
737
3,578
newark
Swift escape 624
If you are on hook up the charger will power the ignition on older vehicles
andy63
4,672
15,017
south shields
None
since 1990
Hi . By main battery I take it you mean the vehicle battery..
If with that disconnected you are getting an ignition light on when you turn the key then your leisure is obviously linked in some way...
That would not normally be good practice as it could leave you with a flat start battery..
I wouldn't turn the key to start as it may at best take out a fuse at best at worst destroy some wiring ..
Also the leads to the disconnected start battery will still be live so insulate them when the battery is disconnected till you get it sorted .
Hope I've understood your post..
Andy.
C
cypsela
13
3
morecambe
im a newbie
The reason i disconnected the main battery i was haveing starting issues,it kept on clicking when i tried to start the engine,thought starter was faulty,but when i disconnected the leisure battery,and reconnected the main battery it started fine,auto electric man i think i need,where would the split charge relay be normally located if anyone knows.
