Condensation any Ideas how? (1 Viewer)
RandallC
1,242
3,487
Devizes
A Class Rapido 8096
2012, prior too, 17 years Folding Camper & Caravan
Noticed a couple of times that the ends of the bed sheet are damp and the van wall is wet, presumably due to condensation at the head end of the mattress. We have a Kontiki 679 with a transverse bed over the garage. The is the standard gapping board on the rear wall but nothing at the head and foot of the mattress.
Having to lift the mattress to ventilate and dry is a pain.
Did wonder about cutting a couple of pieces of poly carbonate roofing sheet and sliding those between mattress & wall. (hollow in middle)
Any thoughts on a cure?
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Drill a tiny hole and fill the gap with expanding foam. I bought an endoscope from ebay and was able to see just where the insulation failed.
RandallC
RandallC
1,242
3,487
Devizes
A Class Rapido 8096
The damp is virtually all across the head end of the mattress. Assume it's mainly that end due to the moisture in breathing.
Sue is adamant that she can't manage without breathing.
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
It will definitely be condensation. Sounds familiar to ours
Minxy
32,659
66,565
E Yorks
Carthago Compactline
As a temporary measure try some bubble wrap ... cut a piece for each end of the bed so that the mattress doesn't touch the wall ... not over Sue's head! :xgrin:
Reactions: f6c
Sep 5, 2010
168
8,290
Central Scotland
PVC
Always - off and on
We have similar and I tried some foil backed insulation used for behind radiators - didn't work! Remembered this being discussed previously and managed to find 1 thread where the solution suggested was car carpet glued to the walls with spray glue. I'm going to try this but hubby won't let me glue it (thinks it might get fousty) going to place it round the walls and see how it goes. Can't find the link for the supplier just now but I'm sure it'll be easy to find. Think the thread was from 2010 but I know I've read more than 1 or 2
edit to include link
.http://www.motorhomefun.co.uk/forum/threads/damp-mattress-in-autotrail.20635/#post-251292
43,331
49,467
You need an air gap the same as the rear wall, not insulation.
Placing insulation will cause condensation between the insulation and wall.
The mattress will be dry at the expense of the wall board.
Circulation is the best way to control condensation.
GJH
29,450
38,827
None, now sold
2006 to 2022
In our Autoquest we suffered similar condensation in very cold weather. We used a couple of those car windscreen sunshades sold for leaving in place when the car is parked. Something like Broken Link Removed.
RandallC
RandallC
1,242
3,487
Devizes
A Class Rapido 8096
Thanks to all, plan to try the bubble wrap (Sue says thanks to MinxyGirl for making it clear where the bubble wrap goes> and the polycarbonate roof sheet. Let you know if any better after the next trip out in January.
GJH, do the window blinds work?
Funfair, With respect to windows open or not doesn't make much difference as the mattress touches the side wall so no ventilation. Only occurs in cold weather.
Cinderz, thanks for the link. Have a readof that later.
Papajohn, agreed the old adage of heat and ventilate would cure but alas. Seems a bit stupid for the sake of a couple of inches in mattress length not to put space boards in each end!
Any further suggestions welcome, catch up tomorrow. Glass of red in hand.
Lenny HB
53,448
150,063
On the coast in West Sussex
Hymer B678 DL
Are you getting cold spots from the garage below if so could be worth putting additional heating outlets in the garage.
funflair
19,363
30,276
Guisborough
MORELO palace
since 2012
Open windows takes the moist air that you are expelling out instead of condensing (apologies if you knew this), are you saying its coming from the mattress and then causing damp where it is trying to escape against the cold side wall, there should be general ventilation from under the mattress.
Martin
Lynne Steele
171
189
Lleyn peninsula
Majestic accordo 125
4 years
We have the same problem, after funsters advice we insulted the large garage door which had less insulation than walls, put draught excluder round garage door, and I also leave open the access doors to garage from interior of the van, if we are on hook up I use electric fan heater to warm the space under the bed as we have no heating in our garage, I am also worried about the mattress and think if it was not touching the walls the problem would stop, but that would mean having a new mattress made, quite expensive, but if all else fails may be our only answer.
Lynne
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
Agree with the above re ventilation. 2 Questions, what is under the mattress? & is there any heating in the garage area? If there is no heating in the garage & it is not easy to connect into the blown air, try leaving the interconnecting door/flap open or take it off, I've replaced ours with a piece of sliding steel mesh from a dog cage.
If the mattress rests on a flat surface instead of slats, put some very course foam sheet( as used in pond filters) underneath.
Langtoftlad
8,861
150,869
Langtoft, South Lincs
WildAx Aurora FB [PVC]
Since 2015
Ventilation :xThumb:
"a person loses about 800ml of water per day, half through the skin and half through respiration."
Thus 2 of you are 'creating' about half a litre of water during a night's sleep - that's quite a wet patch :xrofl:
Dazzlin
1,751
6,213
La Marina, Costa Blanca.
1986 Hymer A Class
From 2013
Another vote for ventilation.
As an example, we do not always use our silver screens.
If it's a bit cool outside and we just draw the curtains over the cab we get 'wet windows' in the morning.
Now I always have the cab open and draw the curtain between bedroom and living area before going to bed.
That alone is enough to stop condensation on the windscreen.
We usually try to do the warmer places in winter, even better!
RandallC
RandallC
1,242
3,487
Devizes
A Class Rapido 8096
Thanks folks.
The garage is heated and can get nicely warm. There are hit and miss vents in the top of both garage doors.
The mattress is on slats and the end wall has a ventilation gapped board.
The Problem Is:- the mattress touches the van side walls at head and foot. NO ventilation gap/board. As Lynne says a right sized mattress isn't a cheap option.
Have tried during last outing leaving the roof vent open in the middle of the van. Makes no difference. Bit difficult to ventilate the gap between two touching surfaces.
Like the idea of avoiding the cold. :xgrin:
Reactions: f6c
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
I had a Product back in the 90`s in my first R-V. It was like Corrugated Cardboard but in plastic, about 10mm thick. We cut it to the depth of the Mattress, and fitted it between the outside walls (side and rear) and the mattress. Improved the situation by at least 90%. we assume that the corrugations allowed the circulation of air, plus the "air gap" reduced the temperature gradient. That and Keeping the Toilet Vent ( toilet room was next to the rear bed) "cracked open" seemed to do the trick.
Pete
RandallC
RandallC
1,242
3,487
Devizes
A Class Rapido 8096
Petey,, thanks will have a look and see if I can locate something similar.
RandallC
RandallC
1,242
3,487
Devizes
A Class Rapido 8096
Martin
Many thanks will look at that later. About set off to work, 10 working days left to freedom.
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
@funflair. Great idea. That link looks rather similar to an anti slip mat. Would one of them be suitable?
funflair
19,363
30,276
Guisborough
MORELO palace
since 2012
No it needs to breathe through the length of the product, the picture does not show it very well though.
This shows it much better but I dont know if the product is available in the UK, it also explains how it works better than I can.
Martin
PeteH
6,853
9,030
Rapido, 999M.
Martin
That is probably going to be as good, and the stuff I had I cannot for the life of me find again online!!. So may have gone out of production? (it was 1998!!)
If you try it and it works. Let us know?
Pete
Finvarra
38
93
scotland
Bailey Approach 740SE
Since August 2013
When we got our Bailey approach 740, that,s the original model, we found on the second trip that the bottom of the bed was soaking wet (fixed French bed). Contacted Bailey and it transpired that there was problem with the mattress from their supplier, something to do with different materials used if I remember correctly. We weren't the only ones who had had problems. Anyway, they replaced the mattress by courier and took the original one away, and we,ve not had any problems since. Might be worth checking with your manufacturers before you drill holes in the bodywork?
Lesley and David
