Compass Calypso Cycle Rack HELP!!
Discussion in 'Tech/Mech General' started by alanmgormley, Jun 25, 2009.
  1. alanmgormley
    alanmgormley Deleted User
    Hi, we have just got a 1995 Compass Calypso motorhome and want to have a cycle rack fitted.
    We are struggling to get a recommendation for which sort to buy
    and
    even worse, no one can advise us if they are easy to fit yourself or if they need specialist fitting
    and
    if so, is there anyone who can do it in the west midlands / worcestershire area
    thanks
  2. Johno
    Johno Read Only Funster
    Oct 29, 2008
    88
    38
    Kent
    Hi Alan
    If you can get hold of a copy of this months MMM there is an article by John Wickersham about fitting bike racks and not what to do also some good tips on what to do, especially regarding the use of load spreader plates and tubing to prevent compressing the bodywork when tightening holding bolts, it's worth a perusal if you are considering doing the work yourself.
    Regards John.
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,803
    6,063
    Mansfield,Notts
    If you can put a shelf up you can fit a cycle rack
    there pretty much all the same
    Fiama has the biggest section I think, and are very simple to fit
    Try and work out the best possible places for the bolts to come through
    usually inside a cupboard at the top and behind furniture or cushion at the lower points,
    If thats not possible don't worry the Fiama kits come with spreader plates and a neat white plastic box to cover the plates and bolts inside, you may still use the covers even if the fixings are hidden
    once you have decided where its going to mount, select the rack from Fiama,s list and check specifications to find one that will suite, or as close to your desired mounting points (there may be a little compromise reqd) they are adjustable to varying heights so as to accommodate different mounting points.
    then all you have to do is make sure the rack will carry the number of bikes you need.
    be sure to apply sealant to any outside fittings and test your mounting area with a firm push,there should be very little flexing or movement
    Have fun :thumb:
    Geo
  4. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,013
    5,323
    Wirral
    Dave Newell in Telford should be abl eto assist.
  5. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,396
    5,426
    East Sussex 01-580-881288
    If you give Darren a ring he wil be able to advise you as to what Fiamma rack is suitable and if you tell him you are a Funster, you will get the discount!:Smile:
    Peter
  6. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    Be very careful about who you choose to do the work, there are plenty of cowboys out there.
    In my own case I had a bike rack fitted but the dealer I bought the van off and inside 12 months the wight of 2 bikes pulled the backing plates clean through the vans back panel.
    After that plus 2 or 3 more cowboy episodes I now do all the work my self.
    Don't be reassured by the price or size of the dealership/workshop get a word of mouth recommendation.
    Doug...
  7. magicman
    magicman Read Only Funster
    Dec 22, 2008
    6
    Alan, I have a Compass Calypso and it has a bike rack already fitted.
    I'll take some photos and see if it has a 'name', and will post tomorrow - if I can. I have a full day tomorrow, and then I'm travelling up to Huddersfield overnight (from London) for a night's work - then home late Sunday.
    Regards,
    Dave
  8. magicman
    Dec 22, 2008
    6
    Sorry I didn't get to this sooner. Here are the pics I promised - finally!!
    [​IMG]
    [​IMG]
    [​IMG]
    Dave
  9. 6pm Cowboy
    6pm Cowboy Read Only Funster
    Jun 26, 2009
    954
    South Oxfordshire
    Considering I dont even own a MH I probably shouldn't be getting involved in this but I will :Smile:
    Could you not fit a tow bar and use a normal car rack ? I have three bikes on mine and it wouldn't need to connect to the fibreglass at all
