Comfortmatic & cold feet - solved! (1 Viewer)
mikebeaches
5,394
8,601
Bristol
Rapido V68 Van Conversion
Since 2009
I posted some time ago that I couldn't get my feet warm in winter when driving our 2016 Fiat Ducato X290, with comfortmatic gearbox. Passenger side was fine, just the driver's side that wouldn't get warm.
Previous 2010 Ducato X250, with manual gearbox, lovely toasty warm feet, therefore assumed there was a problem with the new van.
So asked local Fiat dealer to investigate - response, "There's nothing wrong". I said there must be!
The technician said, "well there is a large plastic footrest on the Comfortmatic which may be directing the warm air away - do you want me to try removing it?"
Upshot, now have toasty feet when driving and I can stretch my left leg out 'properly' too! (y)
So anybody with cold feet on a comfortmatic, check out the large plastic footrest, which can be removed (and replaced if necessary).
Charlie Farley
48
54
Powys
Dethleffs I7150
Sounds fantastic, do you have any photos or a walk through on how to remove it? I did have a brief look sometime ago when my fiat dealer explained why my feet never got warm.
I did wonder if the centre face vent pipe could be removed and placed above the pedal box.
mikebeaches
mikebeaches
5,394
8,601
Bristol
Since 2009
OK, here are some pics - a couple of the large plastic footrest that has the effect of deflecting the warm air up under the dash and away from the driver's feet. And the other pic is of the footwell in the cab after the plastic has been removed, which I think now looks very much like if you had a manual gearbox (but obviously the clutch pedal would be just there in the space). As I said, the garage technician actually removed the footrest, but I think it is just a couple of bolts to undo, then unclip?
Lenny HB
53,430
149,987
On the coast in West Sussex
Hymer B678 DL
I get cold feet for a different (footrest not in the way on LHD). I find when it's cold outside and the sun streaming in the temperature sensors above the heater controls think it's hot so it turns the heat down. I have to turn the heat up to 30 deg to get my feet warm then after 10min turn it down before we roast, so much for auto systems.:)
gerry mcg
1,650
2,573
Glasgow, Scotland
Globecar 600L Revn
since 2016
super... I managed to remove this from my MH last night ... I was struggling with cold feet in my new van - lets see if it improves things - it definitely looks to have cleared 3 vents in the floor... I hope warm air (rather than cold air! ) comes out of them!
Thanks! :)
mikebeaches
mikebeaches
5,394
8,601
Bristol
Since 2009
Thanks! :)
Ah, I rather assumed the holes in the floor might have cold air coming through them - so I've stuffed them with pieces of foam - they are covered by the carpet in any case.
The heating in the footwell, as I understand, comes from the centre of the cab below the dashboard and blows to both sides directed onto the feet. However, the comfortmatic footrest shields and impedes the flow of air, deflecting it back up under the dash on the drivers side, rather than onto the driver's feet.
Hope you get warmer feet now! (y)
It occurs to me that the leg-rest / steering column shield is of course only fitted on right-hand-drive Fiats!
Charlie Farley
48
54
Powys
Dethleffs I7150
After taking the foot rest off I decided on a little mod before replacing it.
Cut a 63mm before inserting a standard vent. I then fitted the ducting adapter, once assembled I secured it with 4 small self tapers. I then cut the adapter in half to create a deflector. Good airflow across the whole food well, happy days
mikebeaches
mikebeaches
5,394
8,601
Bristol
Since 2009
Wow, that looks innovative, and very professional.
However, I like the extra legroom as well as the warm air, so I'll be leaving the footrest off mine for the time being.
But if your modification works for you, then it's all good. (y)
Charlie Farley
48
54
Powys
Dethleffs I7150
@mikebeaches, totally get the extra legroom The finish behind the foot rest on our A class is not pretty so a had to find a better solution, hope this helps other A class owners with iceberg feet
Who Me
9
Shrops
Van
since 2008
Who Me
9
Shrops
Van
since 2008
View attachment 159983 View attachment 159984 View attachment 159985 View attachment 159986 View attachment 159987 View attachment 159988 After taking the foot rest off I decided on a little mod before replacing it.
Hi,
First day on this site and it is already paying dividends.
I get the cold feet bit on my VW as well and soon to have a Fiat Ducato.
Where do you get the standard vent from as I like the look of your modification and would like to do something similar.
PG
mikebeaches
mikebeaches
5,394
8,601
Bristol
Since 2009
Hi,
PG
I can't specifically help with your question. However, I should make it clear it was only an issue for me because we have the comfortmatic semi-automatic gearbox. I don't believe there is any problem with the standard manual gearbox model of the Ducato - certainly not on our previous one, in any case. On that one I normally had toasty warm feet when driving.
Who Me
9
Shrops
Van
since 2008
Who Me
9
Shrops
Van
since 2008
Mike,
It is a comfort-matic that we are getting.
So the change would be of use.
Just hoping I can make such a tidy job of it
PG
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
@Charlie Farley it looks like the deflector pushes the air to the centre of the footwell rather than where your feet are??
Apr 30, 2018
1,993
4,425
Mid Suffolk
Adria Matrix 670DC
Motorhoming since 2018.
Thanks to MikeBeaches and Charlie Farley. I've just done mine, was a relatively easy job to do. The hardest bit was pulling out the plastic pin on the floor and undoing the 1 x 6mm nut which, together with 2 self tapping torque screws at the top hold the footrest in place. Then remove 2 short self tapping torque screws just inside the small storage pocket (Mine has the gauges for the Air Assist suspension). then the large panel simply unclips and you can remove right out of the way. On refection, you don't need to remove this large panel. I did, as I was querulous to see where the air duct outlet was.
See photos below.
mikebeaches
mikebeaches
5,394
8,601
Bristol
Since 2009
Hi Derry - looks like an impressive job you've done there!
Hope it results in warmer feet. (y)
Reactions: f6c
Riverbankannie
10,533
61,537
Bristol
IH 630 RL PVC
@mikebeaches and @Derry Wilson
Husband would like to do this mod on our 2016 Ducato with Comformatic
He is having difficulty accessing the 2 screws and the 6mm nut that hold the top of the footrest because they are behind the lower dash panel.
Any tips? Did you have to remove anything else?
Thanks in advance
mikebeaches
mikebeaches
5,394
8,601
Bristol
Since 2009
Thanks in advance
Hi Annie
I don't remember anything else having to be removed, but I didn't do it - the Fiat technician took it off, while I was standing next to him outside the van. I guess he knew what he was doing, and may have undone something else to gain access, but unfortunately, I don't recall.
Hopefully one or more of the other folk on this thread who have removed the footrest themselves will come on and advise.
Ever so sorry I can't give you a more helpful answer.
Riverbankannie
10,533
61,537
Bristol
IH 630 RL PVC
Hi Annie
Have found lots of posts where someone says “the guy did it in 3 minutes” or something like that. !:rolleyes:
The best I’ve found so far is this YouTube video which is great except he skips over the lower dash panel removal and replacement a bit quick!
He puts it back on at 5 min 30 sec.
We like his double air vent solution though :)
Apr 30, 2018
1,993
4,425
Mid Suffolk
Adria Matrix 670DC
Annie
The two 2 short (25mm) T25 self tapping screws just inside the small storage pocket. If you at a look at the photos you can see the green handled torque driver which I used, remove these. Also see other images which may help.
  • Fiat Ducato 2016 Foot rest removal to install vents to improve warm air to drivers footwell. .pdf
Apr 30, 2018
1,993
4,425
Mid Suffolk
Adria Matrix 670DC
Apologies for the many typos. Now corrected. see attached pdf.
  • v2Fiat Ducato 2016 Foot rest removal to install vents to improve warm air to drivers footwell. .pdf
Riverbankannie
10,533
61,537
Bristol
IH 630 RL PVC
@Derry Wilson Thank you so much for these photos and descriptions. What a fabulous neat looking job you’ve done.
If himself cannot do it now ........ I’ll tell him never to complain about his cold feet again, or ....... I’ll be back later to ask more questions :whistle:
We are going away for a few days tomorrow and I’ve promised to drive so that he can have the warm air in the passenger side :D
Lanerboy
1,363
2,206
midlands
Carthago 4.9 superior
I have just done this modification and going away Tuesday for 3 weeks so will see if there is any difference
Must say it was not the easiest job on an A class when your not built for small spaces :whistle:
Apr 30, 2018
1,993
4,425
Mid Suffolk
Adria Matrix 670DC
@Lannerboy.
I sure you'll feel the benefit. massive difference.
