Cleaning fresh water tank? 10yrs old
Discussion in 'Tech/Mech General' started by kevo, May 4, 2009.
  1. kevo
    kevo Read Only Funster
    Apr 17, 2009
    28
    Hi recentley bought a Tranny auto-sleeper Its ten years old and stood for most of its life I was thinking of taking the underslung tank off to give it a good clean out what do you think?
    Kev
  2. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    Hi Kev personally I would just fill it up ,pour a little bleach into it let it stand for a couple of hours,then flush it through a couple of times :thumb: Unless you like the idea of crawling under and taking the tank off :Rofl1::Rofl1:
    terry
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,266
    5,253
    East Sussex 01-580-881288
    I wouldnt bother, making work and you might cause problems, theres a product called 'Pipe Flush Cleaner, costs £8-80
    Peter
    Pipe-Flush -has been developed after requests from caravanners for a product which would remove Limescale from water systems, and also for a product to clean and sterilise Water systems.
    Limescale is found in the system when hard water has been used and it is noticeable as white bits floating about in water containers. Limescale can block filters, clog pipes and cause damage to water heaters.
    Pipe-Flush will remove and dissolve Limescale from your water system, whilst cleaning and sterilising, leaving pure fresh pipes, tanks and systems.
    It is concentrated, biodegradable, completely safe, doesn't taint and doesn't stain.
    1 Litre Another unique product from FSD!
  4. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,684
    5,840
    Mansfield,Notts
    You still need the pipework cleaning so as Terry says fill up with mild bleach solution let stand the flush through the taps,hot and cold
    if you dont fancy bleach there is a multitude of sterilising solutions out there, home brew kits, Milton's, all basically bleach though:thumb:
  5. kevo
    Apr 17, 2009
    28
    Thanks guys, don't fancy crawling around underneath just want to do the right thing. Bleach it is.
    Thanks again Kev
