City Water inlet (1 Viewer)
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
hi guys
been thinking of putting a city water feature on my motorhome.
what does this entail as i have a fresh tank , pump etc.
would the correct way be to install the inlet through a pressure regulator and non return valve then T into the pump line with another none return valve to stop the inlet going back into the pump and tank then just use the taps as normal with the pump switched off.
thinking about this for long term use on fully serviced pitches for when we hopefully get warden jobs.
thanks in advance.
43,331
49,467
you need to be careful of the water pipe connections and taps.
euro vans are usually fed by a pump rated at 14 to 20psi so the pressure regulator would need to be rated at no more than your pump.
i reckon your plumbing idea sounds about right though :thumb:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
a real simple way would be via a ballcock valve, if you have access to the tank job done. Though the rest of the system would still rely on a pump.
Jim
Ringleader
Jul 19, 2007
36,421
130,934
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Easily done I would have thought. You just need to bypass your holding tank and have the connection direct to the tank outlet. Rvers use reducers so that the mains pressure does not blow there pipe joints apart.
43,331
49,467
never used mine and probably never will.......
don't relish the idea of a pipe 'popping' off when I'm not there or fast asleep......none stop water until you turn off the mains water. :Eeek:
aba
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
hmm i see positives and negatives to this maybe i just need one of those caps for the tank with the hose connector on it and turn it on occasionally.
it was just an idea i was toying with to make life a little easier if i come up with a solution to the busted water pipe scenario then is possibly a goer.
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
I have a city water connection but will not use it for fear of burst pipes. When I use a PRV to lower the inlet pressure the water flow inside is poor.
I just stick the hose pipe in the filler nozzle.
Jim
:Smile:
Jul 28, 2010
1,710
617
The world
Small car
hi guys
thanks in advance.
do you have micro switches on your taps??? if so no you can not
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
I would have thought the easiest way if you can get at the side of your water tank is to drill a suitable hole near the top and fit an ordinary ball valve to it (about £5). Connect your mains water hose to this and this will then automatically refill your tank whenever you use some water. It won't put any extra pressure on the plumbing and will work with a pressurised or microswitch system.
aba
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
had thought about that but the tank is in between the internal and external floors of the van and not that easy to get to.
i have access to one of the inspection holes but cant get to the outsides of the tank.
which is why i was thinking of T'ing in to the existing pump outlet as i can get to the cold water manifold.
Jul 24, 2009
4,330
104,604
South Yorkshire
Since 1999
What is there to stop the water from continuously filling the tank and dumping the water out via the overflow?
Jul 24, 2009
4,330
104,604
South Yorkshire
Since 1999
He said it would fill automatically when you use some water, no mention of having to keep turning the valve on and off.
aba
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
it would then work like your household toilet cistern.
fill to a pre determined level then shut off.
Apr 27, 2008
11,842
14,071
Hymer low profile
Since 1972
Sorry for the lack of clarity about my cock and ball story. I am not a plumber so may have used the wrong word, but what I meant was like in a WC cistern, fills it up when water level goes down and then shuts off.
It may be possible to get one that can be top mounted.
scotjimland
2,335
10,109
A Woosh bang
Been down this road and it's simpler just to fill the tank as required..
Had ours on mains while working at the pub and the top of a plastic mixer tap blew off in the kitchen.. what a mess.. replaced same with a proper brass domestic one..
The so called pressure reducers sold by RV shops reduce the flow to almost a trickle.. I say 'so called' as they are not pressure regulators, but flow reducers.. not worth a light.. stay well clear of them.
If you go the city water way you need to source and fit a proper pressure regulator, an isolating valve for the pump and a check valve.. Olley has done this, he could tell you where he bought the pressure regulator..
Personally I don't think it's worth it.. easier just to fill the tank each day .. Also, come winter (if you are still wardens) the fresh hose will freeze if left out.. then you need a flat hose you can coil up and store out of the cold.. if it's really cold the site tap will probably freeze.. then you need a watering can and long legs ... the joys of winter motorhoming.. :roflmto:
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
Well, just to add the 'other' side, we've used our city water a few times, with a pressure reducer widget and it was great, pressure spot on and thankfully, reading through some of these posts, no issues. Very odd though, you get used to the pump running when you turn on a tap or flush the loo and obviously no pump, it's, well like magic:ROFLMAO:
I do see the alarmist point of view though, and VERY good food for thought folks:thumb:
We've been at this game 6 years and are only just starting to remember to turn the pump off when we leave the 'van:Doh:
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
I always turn ours off
I am always nagging Sue to turn the pump switch off when not in use... if you turn it off then no water can be pumped out in to the RV if a pipe came away.
When we re-commissioned the van last year I turned on the pump to pressurise all the pipes and soon heard the tell tale pump noise indicating it was pumping water when all the taps were off.. it was the outside shower unit had frozen.. this year I remembered to drain the out side shower down, so with luck tis year it will all be OK.. like Simon I do have a device I got from Darren of RV Spares ...blue thing that reduces city water down to save a problem in the RV due to pressure... Did have an issue with the first one he supplied and yes it does reduce the flow to much.
So now we do not use it.. just fill the tanks with a hose.
Bob
