Cigar lighter plugs
Discussion in 'TV & Satellite' started by pappajohn, Aug 29, 2011.
  1. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,087
    17,755
    YO11 2BD
    i had the misfortune of having two fag lighter plugs literally melt over the last 11 days.
    each plug was rated at 6amps and each running a tv and sat box.
    plug one was a shop bought, integrated double adaptor (fused) and this was running a 15" lcd tv plus a 'porty' sat box....this one wasnt too bad but had started to 'bend' a bit and the spring loaded tip had 'welded' to the casing.
    plug two was one i cobbled together from a 4 way socket bought in france, running a 21" lcd tv through a regulated 12v supply unit plus a Zhender sat box, this one literally melted inside and the fuse shattered.
    it also melted the back out of the socket....bugger really as this is part of the aerial amplifier on an RV.
    it was hot enough to burn my finger on the metal contact when i pulled it out :Eeek:
    in each case there was less than 5amps present.
    so, my advise is DONT use cheap plugs as found on Ebay and high street motoring shops.....it just aint worth the risk !!!!
    i just ordered four Hella/DIN type plugs and sockets rated at 10amps each and will be fused at 3amps each.
  2. Munchie
    Munchie Funster Life Member
    Jul 28, 2007
    8,600
    11,888
    Champagnac-La-Riviere
    I bought a couple of twins from Maplins John. Paid a good price for em but my Aldi ones were the same as yours...rubbish. :cry:
  3. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,282
    16,938
    Liverpool.
    Just bought 5 Hella din types from an old car shop. He let me have them cheap £1 per set male and female,he said he had em on the shelf for years.Am in the process of changing everything to them.
  4. pappajohn
    Aug 26, 2007
    30,087
    17,755
    YO11 2BD
    this experience has put me off cigar plugs/sockets for life ken.....could so easily have caused a fire, especially when away from the van.
    • Like it Like it x 1
  5. pappajohn
    Aug 26, 2007
    30,087
    17,755
    YO11 2BD
    best thing you could do Dave :thumb:
    i dont think it was the plugs not up to the job but the spring loaded center pin, over time, push's the plug out enough to cause electrical arcing across the tip and socket center contact, which gets hot and transfers heat to the plastic body, melting it in the process.
    the Hellas has a positive 'click-in' action and cant come loose.
  6. Munchie
    Jul 28, 2007
    8,600
    11,888
    I only use mine for charging my e cig batts and the laptops and phones. Don't leave anything on when out of the van. :thumb:
  7. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,592
    7,877
    How many watts are the Tv's ??
    My 15" LCD is 50watts so thats 4.16 amps and you will find the sat box is about another 1 amp (12 watts) when powering the LNB on the dish.. So you close to that 6amp limit..
    The bigger tv is possible taking even more ampage.
    Wise move to go with a higher rated and better quality plug.. Also people need to ensure their 12v cigarette sockets are wired up for the job as many are only rated at 5amps..
