CI Autoroller x reg 2000 (1 Viewer)
Biker001
5
1 week
Hi ive just bought my motorhome 1 week ago the water pump keeps running all the time and there is not a lot of pressure from the taps , the heater is gas and there is hot water also i dont have any water getting to the toilet to flush it . It is my first van so not really clued up on these things yet can anybody help before taking it to the shop to get looked at Thanks
Momo
2,499
3,041
Valencia City, Spain
just looking
I'm a newbie.
Hi Biker and welcome to the Fun! (y):welc:
Can't help with your problems but one of the experts will be along soon! (y)
Badknee
7,408
412,824
notloB
Vantage Neo
Living the dream.
I suggest it may be water related, the pump will run till it has built water pressure up behind the closed taps and said pressure will trip a pressure switch that will in turn switch the pump off.
So go the other way with water in the pipe up to pressure, pump off. Open a tap and the pressure drops as the water comes out of the open tap, the pressure switch notices the drop and puts power to the pump which then delivers more water.
Have you got water in the tank?
B
Biker001
5
1 week
Ive had the pump running for about 15 mins but it wont cut off at all its a 10ltr water boiler ive got it works ok but the pump just wont cut out , ive been working on a friends van for over a year with issues like this and sorted his but cant get anywhere with mine
Badknee
7,408
412,824
notloB
Vantage Neo
Living the dream.
Could be pressure switch u/s. A cheap and easy fix.
The power to the pump goes through the pressure switch and it should break the connection when pressure is reached. Even though the pressure is up it may not be breaking the contact leaving the pump running.
B
Biker001
5
1 week
Yeah water tank was full when i started trying it and still 3/4 full now pump in a very awkward place to get to so not easy to view it
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
You might have a separate water tank for the toilet flush. Have a look outside to see if there any filler points near the bathroom.
Pump pressure switches usually have an adjuster. You should be able to get to it, adjustment is very critical and small movements make a big difference.
Allan
MikeD
3,936
3,697
London
IH PVC
Since 2012
I wonder if you have a water leak somewhere?
Is there any water draining out below the van?
I suspect it may be on the line to the loo.
B
Biker001
5
1 week
Morning guys there is no seperate filler to the loo ive looked all over for one , there is also no water draining out anywhere i can see either inside or outside the van
Mar 23, 2012
9,548
32,107
sleights
c class
Might be worth looking at the top of the pump to see if the clear plastic bowl is cracked and letting in air.
David
B
Biker001
5
1 week
I will give it a look Cheers
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Has the Van been sitting for a while before you bought it, could be corrosion in the pressure switch.
Try opening one tap at a time start with the nearest to the pump, could be an air lock somewhere
Oh and welcome biker001
TheBig1
17,630
43,324
the lack of pressure indicates the pump has failed. if its not strong enough to build pressure, it wont trigger the pressure switch. you can buy a service kit with new diaphragm or a new pump. being awkward to get at is quite common and means that maintenance is often skipped
Mar 23, 2012
9,548
32,107
sleights
c class
Would still try the top of the pump first sounds just like the problem with our previous van after the winter. The pump top had cracked (not easy to see and didn't spot it at first ) Then noticed if I touched the pump top it worked!! it was taking in air and so the pump wasn't able to provide much pressure. Top (if needed ) can be bought separately and just screws on. Hope thats what it is!!
David
