Cheap As Chips.. Any Good? (1 Viewer)
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
say this... can't get over how cheap it is and seeing as we don't watch a lot of telly a more attractive proposition than replacing our rubbish current terrestrial set up... but will it prove equally rubbish
I have a decent freesat receiver running spare as we no longer have a dish at home (listed building)
tonka
10,833
21,532
Cannock, Staffs
A class Burstner 800
Since 2000
35cm is a bit to small, dish quality is poor...
You would do a lot better in buying a Sky dish and LNb..Usually lots available on ebay...
http://www.ebay.co.uk/itm/COMPLETE-...233?pt=LH_DefaultDomain_3&hash=item416f7d2ef1
If you are going to use it while out mobile then tripod stands can also be got easy enough.
As for the listed building bit, dishes can be mounted on sheds, on the ground hidden among bushes etc... Even on a tree... Done some really weird installs in my time...
DBK
18,029
48,099
Plympton, Devon
PVC, Murvi Morocco
I suspect it could work with blue skies but the slightest hint of rain would lose the signal.
mjltigger
mjltigger
1,619
2,672
Trowbridge
our listing is strict - we can't change the facade at all so nothing allowed at the front that isn't representative of the era and if we had a sat dish would need it visible from the front... anyway, don't watch enough TV, what I liked about this one was the suggestion that I could use the suction cup to put it on the van so not 'camping' as putting a tripod with a sky dish out would certainly be... but if it isn't going to work then it's probably not worth bothering with.. thanks for your advice
tonka
10,833
21,532
Cannock, Staffs
Since 2000
They do work, Just not the best....
However the difference between what you get on Freesat and Freeview is maybe not worth the bother if it's just for home use.
chrisboyo
1,317
818
Newport South Wales
Autosleepers Sussex Duo
5 + 30 years a tugger
I got a suitcase jobby off ebay for £15
I use the 12v receiver in the van for when we are abroad and there is a sat hook up point available. have used the dish a few times and seems to work ok but a bit tricky to set up , you will need a good sat finder to go with it
Dec 10, 2013
3,423
12,233
South Staffs
Pilote P740GJ
Since 2013
We have a similar one from Aldi, even came with a little freesat box. Used it when we had the Caravan and it worked fine, just a bit of a pain to set up.
Just gathering dust in our garage now as we have Maxview on our Motorhome.
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
mjltigger
mjltigger
1,619
2,672
Trowbridge
Couldn't you install / hide one of these. It's not an obvious sky dish.
We had one on our last MH and it worked perfectly all over the place.
https://www.roadpro.co.uk/retail/product_list.aspx?prod=Fixed+manual+satellite+dishes
We put a washing line up and had people taking pictures to report it.. that was allowed by a sat dish isn't so we would get caught for sure..
