Chausson Eberspacher heater
Discussion in 'Motorhome Chat' started by Dochie, May 16, 2014.
  1. Dochie
    Dochie Funster
    Apr 30, 2014
    14
    3
    Fife
    Just back from touring in the north of Scotland with our Chausson best of 10 which is fitted with the Eberspacher heater.
    I was just wondering if I am the only one who finds the heater noisy.
    I don't mean the fan noise, it is the constant clicking of the fuel pump which seems to reverberate through the van.
    The pump lives underneath the passenger side door step and is fitted with a rubber mounting but if you try to run the heater on low at night it is like Chinese water torture.
    Is this just my van or has anyone else experienced this and more to the point has anybody come up with a way to quieten it.
  2. Pat4Neil
    Pat4Neil Read Only Funster
    Sep 28, 2008
    1,377
    487
    Essex
    The solenoid pump shouldnt be that loud.
    Try taking it out of its rubber mount and see if it helps. ( hold it in your hand at different angles )
    You might need to modify it mounting. Its not critical that it is fixed to a wall or bulkhead, it is however critical that the pump sits on an incline of about 20 degrees (fuel in at the bottom )
    You cannot here my fuel pump at all, but the heater does sound like a jet engine until it gets hot.
    Hope this helps.
    Neil
  3. gozomike
    gozomike Funster Life Member Life Member
    Mar 16, 2010
    876
    663
    Warwickshire - sometimes - but not often
    I have an Eberspacher heater on a AutoSleeper and the only sound I get is from the fan.
