Chasssis upgrade
Discussion in 'Motorhome Chat' started by leeboy, Oct 24, 2013.
  1. leeboy
    leeboy Read Only Funster
    Sep 24, 2013
    136
    61
    Sheffield
    Hi all,
    can anyone enlighten me on weight limit upgrades, can any 3500kg motorhome be uprated to carry more weight and if so how? If so are there any down sides to doing this ?
    Thanks,
    Lee.
  2. Phill D
    Phill D Read Only Funster
    Dec 6, 2011
    4,414
    4,633
    South Wales
    depends what chassis your van is on and what tyres .. google sv tech
    • Like Like x 1
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,351
    5,363
    East Sussex 01-580-881288
    If you do upgrade over 3500kg check your driving licence for correct grades as over 3500kg you need C1 etc
    Peter
  4. Mikeco
    Mikeco Funster
    Sep 26, 2013
    726
    535
    Market Rasen
    It's easier to do if the van has been downplated by the manufacturer to fall into the 3500kg class. Had a Chausson once and as that was on a Renault Cab/Chassis it was only a paper exercise to raise it to 3.8t from 3.5.
    Mike
  5. laneside
    laneside Funster
    Aug 14, 2009
    3,566
    5,568
    Oradour sur Vayres
    We used SV Tech at Leyland and found them very good----give em a ring
    We had ours up-rated to 3850Kg but to do so we had to put air suspension on the rear and bigger rear tyres
  6. Allanm
    Allanm Funster
    Jun 30, 2013
    3,139
    4,281
    Cotes d'armor, France
    Give SvTech a ring and talk it over with them. They will give you sound advice and may be able to tell you if it can be done and if you need any mods. But as above, check your licence entitles you to drive over 3500kg first.
    Allan
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,946
    17,612
    YO11 2BD
    manyvan chassis are rated higher than on the vin plate but to comply with the law they are downplated to 3500kg so Bob the builder can drive it on his car licence.
    no point churning out 4500kg vehicles if the vast majority of younger drivers dont have the correct licence.
    companies such as SVTech already know the maximum design weights for most chassis through previous research and experience so they know any upgrades to tyres , brakes and/or suspension which may be needed for a given weight upgrade.
    as already said by Peter....over 3500kg you need a C1 licence category.
    if you took your car test prior to jan 1997 you should already have C1....after that date you need to take a C1 test.
  8. leeboy
    Sep 24, 2013
    136
    61
    Sheffield
    Thanks all will give them a bell.
    Lee.
