Changing to LED (1 Viewer)
Jerrymjj
100
27
Alton Hants
Autotrail Tracker SE
Newbie!
Can anyone help a newbie please? We have about half a dozen of the type of spotlights in the photo in our newly acquired motorhome. For reasons well documented on here, I'd like to change the bulbs (also pictured) to LEDs. Can this be a straight swap or do I need to remove the old lights and fit new ones? I'd sooner not lose what I already have.
Advice much appreciated, Jerry.
DuxDeluxe
14,664
72,949
Planet Zog
A woosh bang van
You should be able to get replacement lamps - they look the same as the reading lights ion my van. Take one out, google "12v LED lights" and see what you find.:thumb:
Edit - try a look here - Link Removed
Other brands are available - I have not used these people, but just to show
Jerrymjj
Jerrymjj
100
27
Alton Hants
Newbie!
Halogen V LEDs?
How do your new LED bulbs compare with your originals? No need to get the brighter ones? Many thanks.
DuxDeluxe
14,664
72,949
Planet Zog
A woosh bang van
They are bright but harsh light unless you get warm white which is closer to a halogen lamp in output colour
GJH
29,450
38,827
None, now sold
2006 to 2022
It's very much personal preference. The best way to judge is to visit a show where the major suppliers like Aten, Ledbulbs4U &c have stands with the different types of bulbs set up so you can compare them.
smiffy502000
249
124
sutton coldfield
coach built.
hi. just changed all mine. same as yours, straight swap over. go for warm white, gives a similar light to your originals:Smile:
ojibway
531
305
Eastbourne
since 2005
I've had LEDs for some seven years now.
They weren't that good in the beginning - some burnt out - but have improved vastly since. I have now fitted a LED strip which just spliced into a 12v supply with an on/off switch.
I have also adapted some Ikea lights to fit using magnets to keep them in place.
Be creative!!
Mike and Annie:Cool::Smile:
Jerrymjj
Jerrymjj
100
27
Alton Hants
Newbie!
Replacement bulbs
Many thanks. Where did you get your bulbs from?
Sep 3, 2012
7,565
26,097
Cheshire
C Class Elddis 175
8+ years
Hi There
we found some LED M16 warm white bulbs in Poundland and was a little sceptical at £1 each -so bought a couple to try -then went back for more-thry do the job -there is about 12 LED in the bulb they are bright enough for reading but they are warm white
give them a try -they replace the halogen bulb lightd directly -I had no issues with fitting them or requiring any polarity changes.
I havent seen them in other £ shops -just poundland
cherrs
Jim:thumb:
RS_rob
1,010
669
Turnford
I replaced the cheap spotlight hologen to LED in ours on the 1st week we had it & it provides a nice glow but the casing was not designed to take the LED so it got modded & forced ::bigsmile: with a little slicing with a blade I finished it off with some electrical tape to hold it together :ROFLMAO:
its the most used light ::bigsmile:
Just ordered me some exterior LED bulbs & some Interior bulbs festoon & bayonet type & hoping to clap eyes on some LED tubes before I order them :Cool:
ojibway
531
305
Eastbourne
since 2005
The two spotlights were bookshelf lights from Ikea which I adapted. The strip led you can get almost anywhere and can be cut to size.
