changing from butane to propane (1 Viewer)
Apr 27, 2008
319
450
South Wales
a-classs
Today I exchanged 2 of my empty butane cylinders for 2 propane what do I need to get to connect them to my truma regulator EN 61-DS .I have a clip on butane regulator attached at the moment.
scotjimland
2,335
10,112
A Woosh bang
Try here, you need a propane pig tail
Link Removed
karalal
Apr 27, 2008
319
450
South Wales
a-classs
thanks for the reply
I`m a little confused
You say that I need a propane pigtail . so in effect I have a two regulators at the moment
one is on the truma and I have a clip on one on the butane bottle
for propane I do not need one on the propane bottle
JayDee
1,057
169
N. Devon
7 Years after 5 years with caravan.
Regulators
For years Butane and Propane worked with different regulators to give different operating pressures, hence blue for butane and red/orange for propane.
A few years ago it was decide that it was only necessary to have a single standard for both, so now caravans, etc., are usually fitted with a single all purpose reg. But the fitting to the gas cylinders remain different, hence the need for the pigtail. The correct pigtail fits the appropriate cylinder and the other end goes to your installed regulator.
You don't need two regulators, so when you refer to your Truma regulator, that's it. It is designed to work with both butane and propane (or a mixture) and that is where the pigtail goes to.
Sounds a bit confusing on reading it through :RollEyes:, but I hope you see what I mean.
John
