change watermaster filler? (1 Viewer)
david lympany
5
wales uk
elddis autoquest
since 2014
Hi guys
Is it possible to change the above type filler for a conventional fuel type filler cap?
D
david lympany
5
wales uk
elddis autoquest
since 2014
yep just that silly square plug that fills the on-board tank I just want to change it for a normal filler neck
43,386
49,816
That depends on your pump and taps.
under the taps will be a pair of lightweight wires if its non pressurised (microswitched)
if there are no wires its a pressurised system.
It should be viable to change the filler but it will require drilling a much larger hole in the tank to take the boss/stub to suit a larger, maybe 50mm to 60mm, hose depending on the make of filler.....and of course, you could leave the existing hose to fill if you cant get to a tap.
The existing fill hose will only be 12mm id
D
david lympany
5
wales uk
elddis autoquest
since 2014
Ah okay thanks
Where does the pressure come from then? I know that the pump is a whale sureflo. And when I turn a tap on the pump runs even when the tap is turned off. There is also a trauma ultrastore water heater
43,386
49,816
Thats a pressure pump so other than the filler nothing else needs changing.
The external pump is purely for filling....and as i said, can be retained for filling if you cant get a hose to a distant tap.
The pump will run for a short time after turning off a tap while the system repressurises and the pumps pressure sensitive switch turns it off.
D
david lympany
5
wales uk
elddis autoquest
since 2014
Ah okay so whatever means of filling the on board tank is irrelevant then?
I just think a simple hose filler would be easier
Thanks again
43,386
49,816
Another option would be to remove the filler pump and hose from the square fill gadget and connect a hose in its place.
The speed of filling would be no different to using it as is but would save cutting holes in the water tank and sidewall of the van.
43,386
49,816
looks like your free posts are now used so to continue you need to subscribe.....ten quid a year.....worth every penny and help and advise alone will save you that much many times over.
You can continue to read, but not post.
