Chair Rotation (1 Viewer)
terryallan
21
Scotland
Since 2010
My passenger side chair doesn't rotate and I need to release the central nut which holds the swivel plate from rotating. The large round nut has four notches which obviously needs a specialist spanner/tool to fit over it and so turn the nut. I suspect many people will just whack into one of the notches with a chisel and hammer to release the nut - but that will damage the notch. Anyone know if a tool exists and where I can find one to buy?
scotjimland
2,335
10,108
A Woosh bang
This supplier has two makes but makes no mention of a special spanner.. but there are at least two makes, maybe more. Link Removed
If you know the make try Googling for the manufacturer or retailer who may have or know where to find the spanner required..
PS.. I see we have the same surname.. where about in Scotland are you from .. we could be related .. :roflmto:
and welcome to the forum
wivvy's dad
3,205
1,795
48.066895,12.862673
Transit LWB Hi-Top PVC
On and Off since '98
Are you sure it should rotate?
Where is the rotatiion release handle?
What's the vehicle?
We need more info.......
terryallan
terryallan
21
Scotland
Since 2010
Thanks for replies.
The van is a Pilote CityVan CV60H (2008). It is Fiat Ducato based. The handle is on the left hand side of the passenger seat - right hand side of the driver's seat. The seat should rotate. I can see what needs to be done but I don't want to damage the retaining round 'nut'.
The shape of the nut is as below. It is of course threaded in the middle.
Link Removed
wivvy's dad
3,205
1,795
48.066895,12.862673
Motorcycle rear shock absorber preload adjusting collar has similar profile.
Now we need the diameter of the nut as per diagram, or is that to scale.
scotjimland
2,335
10,108
A Woosh bang
C Nut spanner
The spanner you need is called a C Nut spanner.. come in many sizes but now you know what to ask for .. and what it looks like ..
terryallan
terryallan
21
Scotland
Since 2010
C Nut Spanner
Thanks for that information. I remember I used to have one like that for my bicycle many years ago when I had a bike.
terryallan
terryallan
21
Scotland
Since 2010
More information.
It is a FASP seat mechanism.
The outside diameter of the round nut is approximately 65mm or 2.5 inches.
Pictures below may provide further detail. The nut is recessed as shown and so a C spanner may not work - depending on the size of the spanner. It is a spanner more like that used for the nut under the waste on a sink that I assumed I would need.
Link Removed
Link Removed
Link Removed
Link Removed
Thanks again
terryallan
terryallan
21
Scotland
Since 2010
Sink spanner
I found my sink spanner and bicycle C spanner. Of course neither are any good for this job but I took pictures of them anyway.
Link Removed
steles
240
61
Kent
Panel Van Conversion
It looks from the pics that somone has already attacked it with a chisel. Best if all else fails to use a drift with blunt end, will do far less damage. Correct spanner is just a piece of tube like a box spanner with the end shaped to fit into slots in nut. Has the seat not turned from new, seems like a visit to dealer is best option.
Steles
terryallan
terryallan
21
Scotland
Since 2010
Decision
Yes I have decided that I am going to the local dealer.
Thanks again
