carbon monoxide "reiterate the principle of precaution" (1 Viewer)
Dec 6, 2008
46
Lisbon
The body of a man of 43 years and a woman aged 45 were found dead in the night from Saturday to Sunday at Combs-la-Ville (Seine-et-Marne), the survey highlighting a heating failed, it was learned Sunday prefectural and police sources.
The bodies were found lifeless "to 1:20" in their motor home while the couple had attended a party held nearby, said a police source. It is a waterfront, itself involved in the festival that discovered the two bodies and alerted the police, the source said. According to preliminary results of the investigation, the man and woman have been poisoned in their sleep from carbon monoxide generated by a "faulty heating" inside the camper. Upon arrival, police found a generator inside the camper. Investigators were unable to clear Sunday night whether the vehicle was the primary or secondary residence of the couple.
Following this tragedy, the prefecture of Seine-et-Marne wished to "reiterate the principle of precaution" to observe this period of extreme cold. "With temperatures below zero, it is necessary to check carefully before using the heaters, that there is adequate ventilation for this type of gas," stressed the permanence prefecture. The commissioner of Moissy-Cramayel has received the survey.
JaG
Oct 30, 2008
1,375
1,458
Chesterfield
Autotrail Cheyenne
Since 2008
Tragic
This is so tragic. It can so easily happen if proper precautions are not taken. Last year, having just bought our campervan with no heater we had a close encounter. We were at Newark Show and the temperature dropped to minus 4 during the night. Unable to sleep we lit a small portable heater we had that run on the canisters. The van warmed up and we dropped off to sleep. An hour later we were woken by the Carbon Monoxide alarm going off (luckily we had bought one before we left home). Not realising the camper had no air vents it had taken most of the oxygen out of the air. We were lucky, very lucky, to have just a headache the next morning. You can be as experienced as you like ( we have been caravanning over 35 years) but it is still easy to make a mistake. No so for the couple in France.
imprint
1,087
13
1. Use an oil-filled, electrically heated rad when you're asleep.
2 With a decent duvet plus a second, or sleeping bags, you'll be warm enough even if you're as mature as the Senior Partner and I
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Yep we use a small oil filled rad at night. We have a CO/smoke alarm fitted but to be honest it's turned off as the damned thing goes off at the slightest thing (like Steph breaking wind:Eeek:)
dellwood33
878
Newcastle
italian crap
too long
The comment that the police found a generator inside the camper is a strange one. Was the generator being used inside :Eeek: ?
Oct 1, 2007
7,064
13,964
Kirby cross further from londin
Between Motor homes
since 08
i wondered that
but i couldnt see anyone running a petrol/diesel genny
inside their van could they!!!!?:cry:
bad enough when i had a diesel welder in the back of a luton
and a hose out the back
let alone trying to kip with an unsileced one
and the smell in the habitation area of a camper
surley they meant heat generator like a fire or flued heater
unfortunate accident i would imagine but awarning to us all
Aug 7, 2007
669
608
Dundee
Elddis Autoquest 195
since 1975
heating van
Hi to all,with the weather being the way it has i am so glad that we have a websato airtop heater fitted.At new year we were away and the temp was down to -6 degrees before we went to bed !!.Put off the gas heater at that time but woke up a 6;30am cold,switched on the webasto and went back to bed ! wakened up at 8am almost melting with the heat.
As the exhaust is vented outside no danger of co2 gases inside. my heart goes out to the family of the couple who died.
autocaravana adventure
Dec 6, 2008
46
Lisbon
after he learned of this sad news, I put a co2 detector with audible alarm in my motorhome
