Cannot get it to stay up. (1 Viewer)
Aug 10, 2012
75
39
Worthing.West Sussex
Empty Nest
Since 1972
Does anyone know a method of managing to get windscreen camera suckers to stay up?
The one for our camera has one of those "over centre" leavers and initially seems to work okay.
But after a few days it has fallen off- even without the camera attached.
I mount it just behind the main centre mirror.
Betterwear have in their catalogue a device called a dashboard satellite navigation holder which appears to be a circular weighted anti skid device which contours to the shape of the dashboard.
It says it utilises the suction mount which, from the picture, seems to sit in the middle of this ring.
I wonder if anyone has tried one of these and if it could be used for a camera- albeit sighted lower down than normal.
I notice that some lorry drivers put their cameras at the centre of the bottom of the windscreen.
Huskydog
39
59
kent
Lunar roadstar 620
newbie
I have had a camera in the screen of my car for 18months and all I did was to lick the sucker and then pull the lever over, but in my van I use a " dash pad" and put the camera on that as the camera is then out of my view , the pad hasn't moved since I put it on the dash
Jul 29, 2011
2,697
22,222
Urmston, Manchester
Former owner.
June 2012
I had one that was like a small bean bag with the suction ring in the middle it worked perfectly.
Dec 4, 2014
1,372
4,148
Cheshire
Van Conversion
Been around the block a few timesšŸ˜‰
The ones we have are always falling off in direct sunlight & setting the alarms off :-(
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Once mine is up, it stays up till I decide to remove it.
Make sure the place where you want to put it is grease free and clean, then dampen your cup and go for it.
My dash cam has been up for almost 3 years without falling off.
The length of time it stays up depends on the quality of your sucker.
Mines a RoadHawk.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Temperature goes up and the liquid dries out then it leaks air so the sucker drops off, dot of superglue will fix it. I SAID DOT.
Feb 22, 2008
12,266
45,055
Norfolk
Nearly Tugging
Since 2004
My roadhawk sucker also stays put, as above probably quality of sucker .
Petest
199
185
Uk
New convert
Use some viaggra to stick it up - should stay up longer
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Since 2010
(y) Mine seems to stay up well, never tried that viagra on it.
Would it dribble on the screen?
I do wash/wipe it regularly tho.
43,331
49,467
You need to wet the sucker, preferably with spit as its a bit thicker than water, and make sure the screen is clean and grease/polish free.
Also, check the glass behind the mirror as many screens now have a pattern embossed around the mirror area, usually a black mesh effect, and the sucker wont stick to that as it isnt flat.
My satnav mount has been on the screen for the last year or so.
Apr 26, 2015
2,770
6,894
Ottershaw
Hymer S820
First motorhome May 2021
Make sure the screen is clean first, wipe over it with meths or alcohol wipes, make sure the sucker is clean and grease free and then try again with a little moisture on the sucker.
S
Aug 10, 2012
75
39
Empty Nest
Since 1972
Rosie says to thank you for all of your helpful replies 'cos she is fed up with having to keep sticking it back up.
