Calder Kountrylite Help (1 Viewer)
GIBLA53
267
25
Powys/Spain
Adria Coral Compact
since 2002
Hiya
Any suggestions as to : about every 20 secs. a high pitched single squeal seems to originate about mid-van. I have tried the obvious things like smoke-alarm batteries but all to no avail - next step is EAR DEFENDERS never had the problem in the previous 18 months
Al.:Eeek::Eeek::Eeek:
lorger
9,663
90,508
Dumfries
Knaus Sun 650MEG
Was going to say smoke alarm do you have an inverter on board when we had one it would start to make high pitch noise when your battery get below certain voltage. Apart from that id go for the ear plugs you can get inside ears loads better:ROFLMAO::ROFLMAO:
scotjimland
2,335
10,111
A Woosh bang
As already suggested, low voltage inverter alarm..
are you on EHU or not ?
GIBLA53
GIBLA53
267
25
Powys/Spain
Adria Coral Compact
since 2002
On EHU. never had the problem before !!! if i could some guts would be ripped out of something to make it stop!!
Al.
GIBLA53
GIBLA53
267
25
Powys/Spain
Adria Coral Compact
since 2002
LPG alarm fault - i think this may be the problem .............anyone any suggestions how to sort it out/disarm it?
Alan
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
As others have said, the most likely is the lpg alarm, which will be mounted close to the floor.
Check the voltage and make sure that it is over 12volts.
Assuming you do not have a gas leak or have recently cleaned the carpet with chemical cleaner, use a vacuum or air pressure to clean the sensor on the unit, dust will sit on it and give a false reading.
In your 12 volt fuse box there will be one fuse that will cover that alarm, remove this fuse if all else fails, at least it will be quiet, BUT establish 100% you do not have a gas leak first.
I understand that some alarms have an integrated battery, if this the case make sure it's not flat.
Good luck.
Nigel and Pamala
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
Reset button no good?
Pull it out and check connections and voltage, though these are usually permant feeds from the leasure batteries and maybe try vacuming it, I'm sure I read somewhere recently someone advising the same for a dodgey LPG alarm?
GIBLA53
GIBLA53
267
25
Powys/Spain
Adria Coral Compact
since 2002
Success!!!!!!!!!!!!!!
YEEEEEEESSSSSSSSSS sorted out !!!!!!!!!!!! simply went to LPG alarm (lower middle of van) played about and held in the reset button , light changed from amber to green to no display shown at all Atwood lpg sensor btw.
EAR DEFENDERS PUT AWAY thanks to all who helped (it makes a massive difference to be able to ask funsters for assistance)
Alan:Smile::Smile::Smile:
