Calculating axle weights with a tag axle Motorhome (2 Viewers)
Jim
Ringleader
Jul 19, 2007
36,447
131,031
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I'm working on an FAQ and I've found a hole in my knowledge.
I'm well acquainted with the formula for working out axle weight changes when you add a load to your overhang and I'm writing an article about it for the forum. But I need to ask you cleverer Funsters than me.
Tag axle motorhomes; where is the pivot point? Rear tag/front tag/in-between?. As you may know the calculation requires the wheelbase and overhang measurements, easy in single and twins but on a tag; where are these measured to accurately determine new axle weights when weight is added to the rear? Thanks
19,374
30,360
Hi Jim
I am going with in between the two rear axles, this is assuming a reasonably level van as you could argue that when it is well overloaded and the front wheels are in the air that the pivot point should be the centre of the rear axle, mind you most/some people would work out for themselves that they had too much weight in the garage in that example.
The distance between the tag wheels is small compared to the other two distances, so if you go for middle of the two wheels and then divide the load equally you won't be totally accurate but for most purposes close enough.
If it was really on the limit at a weighbridge you could come unstuck but deserve to if loading that close to the limits.
I do not know but I wonder if the way the two axles mount on the rear springs does not share the load equally by allowing a bit of twist.
JockandRita
11,464
150,284
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
I can't answer your question as much as I'd like to Jim, but my experience at a weighbridge with our "Tandem" axle MH, is that the intermediate axle bears more of the load than the rear axle, (not by a great deal though) as the figures show on the official VOSA ticket. This has been when loaded up for a fortnight's holiday, including bikes on the rear rack.
BTW, although we all use the term "Tag" axle, a Tag axle is one which can be raised and lowered, and in the case of a 6 x 4 or 6 x 2 Tractor unit (eg, Scania, Volvo, Renault, etc), they are often operated automatically via load sensing valves. ;)
HTH,
Jock. :)
Jock. :)
The actual figures would be very interesting if you still have them. Is there a big difference ?
And of course, is it the same for all tandems and how dependent on you actual loading is it ?
Reactions: Jim
19,374
30,360
HTH,
Jock. :)
Are you a bit nose down Jock as that would do it if all other things, (suspension units etc) were the same.
JockandRita
11,464
150,284
Lincs/Cambs border
N+B Flair 8000i
I've no access to them at this time Brian, as I'm at work (boring :( ) and the MH is in storage, but IRC, there wasn't a great difference between the two axle weights. Also, you can often see by looking at the tyres (equally inflated) that the intermediate axle is bearing more weight.
Cheers,
Jock. :)
JockandRita
11,464
150,284
Lincs/Cambs border
N+B Flair 8000i
Yes Martin, even after a Goldschmitt front suspension upgrade, I am still slightly "nose down".
Cheers,
Jock. :)
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
I believe what you are looking for Jim is the "Fulcrum effect on loading say a scooter on a rear rack
and fulcrum point is the swivel point ie center of the rear most axle
calculated by taking measurement from the rear panel to the first swivel point it therfore follows using a load calculator would be from the front wheels to the swivel ie the rearmost axle
for the purpose you require I believe the other axle can be ignored, as it not relative to either measurement
Further confirmed by this experiment
Remove rearmost wheels and the swivel point (Fulcrum) changes to the other axle
Then put them back on
remove the wheels from the middle axle and nothing changes ergo the centre axl has no relevance at all
G
Reactions: Jim
19,374
30,360
G
But that argument says that all the extra effect of loading a scooter on the tow bar would go onto the rear axle, which is not the case. I can understand your argument if the front wheels are of the floor but not sure if the van is basically level. When I first looked at it I thought rear was the answer but changed for a a level van where I believe you treat the two axles as one.
Will keep thinking.
andy63
4,672
15,018
south shields
since 1990
I was thinking along the same lines as @Geo .. but wasn't sure how to get it across lol...
Anything added behind the rearmost axel will have a fulcrum effect around that axel... and lighten the load on the front axels. .
Interesting anyway...
Apr 10, 2010
552
544
Bedfordshire
Carthago
Since Sept 2003
Some recollections from when I sold trucks some 40 years ago. We had what amounted to a slide rule for calculating weight distribution and turning circles (among other things). In all cases with twin rear axles the measurements were taken from the midpoint between the two rear axles. This is only completely accurate when the van runs level, as Martin says, and when the suspension for both rear axles is identical. On mine, the rear air springs are interconnected to achieve this. With a van slightly nose down there will be more weight on the leading rear axle.
However, on most weighbridges it is not possible to measure the two rear axles independently, so they would be weighed together and their capacities added together to give the weight limit.
So when adding a scooter rack I believe it would be proper to measure the wheelbase from the centre of the front axle to the midpoint between the two rear axles, and the overhang from the midpoint of the two rear axles to centre of gravity of the scooter.
Apr 10, 2010
552
544
Bedfordshire
Carthago
Since Sept 2003
PS - it wasn't long ago that I threw away the slide rule! Isn't it always the way - don't use something for years, chuck it away then find a use for it :oops:
eddie
8,159
41,279
Taunton Somerset
RV
since 1989
I have no technical experience of this but have witnessed a phenomenon which may have a bearing.
We have two vehicle parking areas, one for cars and one for motorhomes and the first bay has a slight slope initially
When Tag axle vehicles try to reverse on to slot one, if they turn too tight, the front off side wheel simply lifts off the ground as the nearside is on the slope.
This would leave me to think that the pivot point must be close to the leading rear wheel, if the front wheel will leave the ground will no apparent ill effect
2657
In another life, a long........long time ago, I studied Mechanical Engineering(long forgotten now) but I vaguely remember very complicated calculations for distributed and point loads on beams, which is effectively what a chassis is.
My instinct tells me that an accurate answer would not be simple but the methods suggested would give a fairly accurate approximation.
I am sure that there are other Engineers with far more knowledge than I on this forum that could give a definitive answer.
18,035
48,140
The middle wheel so to speak will carry a bit more weight but the difference won't be great.
To calculate it in the absence of a diagram imagine the level MH pivoting around the front axle. Then imagine the weight of the MH pressing down below the centre of gravity at a point somewhere between the front and rear wheels. As the MH isn't actually moving (rotating) then this "moment" as it is called is resisted by the combined moments from the rear wheels.
The rear wheel being further away, and thus having a longer lever, will have less force on it than the front tag axle.
This assumes all things are equal and the rear springs being equally compressed. If they are not then the distribution will be a bit different but I think if you assume the force lies equally between the two rear wheels it will be good enough given the other variables including variations in tyre pressure.
18,035
48,140
Further to the above if you assume:
Tf = force on front tag axle
Tr = force on rear tag axle
x = distance between tag axles.
W = distance from the front wheel to the front tag axle
Then:
Tr = (Tf * W) Ă· (W + x)
So if x is only a small fraction of W the difference between Tf and Tr will be small and the mid-point between the two can be assumed for calculating axle weights.
All of this assumes there is no connection between the two tag axles, such as linkages or that they are on a "walking beam" where the load on each wheel would be identical.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
I made no reference to load bearing shared or otherwise as that was not the question asked.
The question again was which axle do i use for the calculation of adding a load to the tow bar
The axle to use is the rearmost of course the load will be shared but that question was not asked
the equation reqd is the distance between the front and rearmost axle regardless of how many axles it has got, add another in the middle and use that, and you have the wrong formula
A1 = existing front axle load
(before adding on the new rear load)
A2 = existing rear axle load
L = weight of new rear load
W = wheelbase (the distance between the front and rear axle centre-lines)
O = overhang (the distance from the rear axle centre to the centre of mass of the new rear load).
Add the figure for the new rear load, and carry out the following calculations:
  • New front axle load (new A1) = A1 – [L x (O Ă· W)]
  • New rear axle load (new A2) = A2 + L + (A1 – new A1).
denisejoe
5,625
12,055
Warden isle of sheppy
I can speak from experience because if you put a scooter on the back it lightens the steering so it must put more weight on the rear axle and pivot round the middle axle.
joe
19,374
30,360
joe
It certainly takes weight off the front axle so therefore applies more than the actual scooter load onto the rear axle, in fact the weight on a single rear axle would be the weight of the scooter plus the weight taken off the front axle, I think we all agree on that but its two rear axles that is causing some confusion.
19,374
30,360
OK
Can I change my answer @Geo has to be right that the fulcrum point is the centre of the back axle, I have been out today but when not out I have been drawing and calculating turning moments on scraps of paper and the desk is now littered.
The effect of a load on the towbar has to be a moment around the rear most axle.
I think for the purpose of @Jim 's calculation it would be OK to calculate a tag/tandem axle as a single axle but using the rear one as the fulcrum/pivot in the calculation and then sharing the result between the two axles.
Doh, my brain hurts.
Badknee
7,408
413,021
notloB
Vantage Neo
Living the dream.
For weighbridge purposes @Jim when I was driving eight wheel tippers we only weighed the two front axles together and the two rear ones so as has been said on close coupled tags there can't be much difference between them.
Reactions: Jim
18,035
48,140
G
Your last statement is wrong. Remove the front wheels of the tag and the rear most wheels will suddenly have added to them the load that was being support by the front tag wheels and the suspension will sink down significantly.
To some extent the scooter is a red herring because adding one only shifts the centre of gravity of the MH rearwards a bit and the whole motorhome still remains supported by the axles, be there two or three. As the scooter overhangs the rear the front axle load will reduce slightly and the rearmost axle loads will increase but the total load supported is still the total weight of the MH including the scooter.
The MH would only "pivot" around an axle if the centre of gravity was directly above it. Given that in reality the c of g is in front of both rear axles then both axles, if there are two, each take a proportion of the load.
As I tried, badly, to explain earlier the difference between the loads on each axle won't be great, the difference as a proportion roughly being the distance between the two tag axles divided by the wheelbase, which typically might be 10%, all other things being equal and the vehicle is level.
Reactions: Jim
JockandRita
11,464
150,284
Lincs/Cambs border
N+B Flair 8000i
Here you go Brian.............
Plated Axle Weights.
1. 2000Kgs
2. 1500Kgs
3. 1500Kgs
Actual Axle Weights. (at the time)
1. 1750kgs
2. 1380Kgs
3. 1240Kgs.
Although the axles are listed in numerical order, they were weighed by VOSA (as they were known at the time) in the following order, on a very modern purpose built axle weight measuring plate, rather than on the full sized vehicle weight plate.
Weighed In Order.
1.
3.
2.
The MH was weighed with full water, diesel, and gas tanks, and bikes on the rear. Only clothes, food, and SWMBO were to be loaded after the above weigh in. Not a lot more weight, eh? ;)
@hilldweller, I am unable to answer the second part of your question quoted above Brian, however I do agree with the comments by @funflair in that if the MH is slightly nose down, (as most Fiats MHs are) this imparts more of the load from the rear axle, onto the intermediate axle.
HTH,
Jock. :)
jonandshell
5,476
8,299
Not got one!
Many HGVs use either a bogie arrangement or equally pressured airbags to evenly dristibute the load over a twin axle arrangement. You can be assured that the load centre is firmly between the axles in this case.
Less complex Alko twin axle chassis use torsion bar trailing arm suspension right? So, not really axles!'!
OK, the load on the 'axles' is dictated by the attitude of the loaded vehicle.
If it is nose down, the front 'axle' in the pair will suffer more torsion bar loading and thus more force on the wheels and in turn more force downwards on the weighbridge.
If the vehicle is nose up, the front 'axle' in the pair will suffer less torsion bar loading than its twin and therefore less downward force on the wheels. This creates less downward force on the weighbridge.
In reality though, the roads surface is never completely flat and the load will always be shifting dynamically between the four wheels of the Alko chassis.
Using their mid point as the theoretical load centre is most appropriate in my opinion.
