Cadac question (1 Viewer)
Manouche
135
Southsea
20 years
We have a Cadac Safari Chef, which we love using, however get a bit fed up with changing the cannisters.
Does anyone know if it's possible to fit an adaptor which will allow me to run it with a bigger gas bottle via a hose and regulator, something like a large camping gaz.
I've tried emailing cadac direct but as yet, no reply.:help:
43,329
49,446
shouldnt be a problem as the pic shows....dumpy bottle and regulator. just buy a suitable reg to fit your gas bottles. may need re-jetting though.
Link Removed
43,329
49,446
Ooops, my mistake....
looks like you have this type and the control valve is different.
Link Removed
imprint
1,087
13
The Senior Partner, who uses our Cadac which is just fantastic, thinks PJ is right, but adds that Cadac is a very helpful outfit indeed, so write, e-mail or phone and you should get somewhere.
It seems you may have bought the wrong bit of kit, so sell it having done the research and get what you need. Our butane bottle is just like the one in Old FatherJohn's first picture.
43,329
49,446
i use our cadac carrychef D/L using the external BBQ connection point on the van so dont need to carry 'extra' gas for it. :thumb:
best way to go...
Manouche
Manouche
135
Southsea
20 years
best way to go...
Yeah, i would too, if, I could find an adaptor to convert the gas inlet to the burner to a rubber hose instead of a threaded cannister.
I was hoping somebody might have done the mod before.
haganap
12,759
26,448
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Why not get Ash to fit you one at Stratford? much better than carrying extra bottles:thumb:
43,329
49,446
its not the BBQ point at issue Paul.....manouche has a cadac with a CANISTER type bottle connection...like a screw-on type connection and no hose/reg....he needs an adaptor to convert the BBQ to calor bottles
capinpugwash
511
629
Hampshire
Since 2005 (20 years Caravan before that)
Cadac
I have a Cadac like yours. I run it off a blue Calor gas bottle and use the regulator that you are after.
I got my hose, regulator and the fitting that screws into the Cadac from an online company called.
Make sure you get the right regulator, as there are 2 types that look identical, but are 1mm different in diameter. You need the larger of the 2, but Outdoor Bits will advise.
Hope this helps
Stuart
capinpugwash
511
629
Hampshire
Cadac
They can also supply the part that connects to the outlet point on the side of the van if you have one.
Hope this helps
Stuart
Manouche
Manouche
135
Southsea
20 years
Thanks for that Capin, I'll have a look at Stratford and take it from there.
At least I've got somewhere to start.
