Cadac problem (1 Viewer)
malheg
175
72
Coppull (Chorley)
Campervan (Alphard)
12 yrs
I have the large cadac BBq.
The gas keeps blowing out for no aparant reason, even when there is a slight breeze.
I am confident my gas pressure and supply are OK.
Can anyone shed light or offer help.
Malc
7
7735
I posted on this problem yesterday. I have read the booklet that came with my cadac and it states it should be used with a 37mbar regulator if using propane. I have been using mine via my external gas point but the regulator fitted in van is 30mbar. I have fitted a 37mbar reg and will try it with a gas bottle. If mine still blows out I will chuck it.
spongy
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Have you checked the fire tube (or whatever it's called)? We have both mini and larger Cadacs. The latter stays at home now and we use it in the garden from a Calor butane bottle. Last year we took it our daughter's house to use for the first time in a few years and the flame was weak - dinner took ages to cook! Upon dismantling the unit I found a spider's web / egg ball in the tube between the gas pipe attachment point and the burner (underneath the blue metal body of the Cadac). Once cleared, all returned to normal.
It might be worth a look.
43,329
49,446
was going to say the same but a partially blocked jet would also have the same effect
Nov 30, 2009
6,547
148,995
Pickering
PVC the PUG
Or a partially melted one , as in our case. It didnt set on fire , like some we have known about in the past.:whatthe:
After contacting cadac they sent out a new one. Free of charge.:thumb:
Jun 22, 2011
507
1,305
Onchan, Isle of Man
Carthago
Since Nov 2010 after 25 yrs under canvas.
cadac
we have tried two cadacs and given up. They do not work for us at all! If there is a slight bit of movement in the air they are useless!
Jaws
23,836
72,486
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Both Nemo and us use a large Cadac regularly
Only had a problem once and it was blowing a hoolie !!!
malheg
malheg
175
72
Coppull (Chorley)
Campervan (Alphard)
12 yrs
Cadac
spongy
Thanks.
I have the same set-up, but I understood all new regs are 30mb.
Interested to know how you go on.
Malc
malheg
malheg
175
72
Coppull (Chorley)
Campervan (Alphard)
12 yrs
Cadac
We had same problem, finished off dinner cooking in van.
Malc
pablomc
772
237
Durham
Since 2009
I keep forgetting when using the paella pan, to use it direct onto the flame and keep trying to use it with the BBQ deflector (black) which will result in continuous extinguishment of the flame. Just a thought. :Smile:
Also you can use the lid hooked on the side when there is a breeze to act as a wind block.
7
7735
Hi Malc
We are of to windy wales tommorrow for 2 weeks, will let you know if we still have the cadac when we come back!
spongy
Chris
21,054
278,769
None
10 years
that's a shame I'm coming to Hampshire for the weekend I could have collected it.
If you are ever anywhere near Sidcup Roger you can have ours. I meant to tell you that before but kept forgetting:Doh:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
cheers Chris. Septemberish unless you are coming to the Ilfracombe rally in August or know someone who is passing.
Chris
21,054
278,769
None
10 years
Thats fine. Can't make the Ilfracombe bash as we are away then.:thumb:
