c250 toilet cassette
Discussion in 'Motorhome Chat' started by gpz, Jul 28, 2016.
  1. gpz
    gpz Funster
    May 24, 2012
    94
    4
    north yorkshire
    may be a silly question when the toilet cassette is full with flap closed should i be able to stand it on end without it leaking mine is leaking badly .we were get a urine smell in the motorhome and when i emptied it and cleaned it out ,i refilled to flush it out stood it up and it was leaking a lot not long since had new lip seal do the flap which goes over the lip seal leak any help appreciated
  2. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,540
    9,962
    the blade and main seal should not leak. if the seal was changed, are you certain it didnt kink? if not you need to renew the blade
    To soak up spilled urine use cat litter as it also deodorises
    • Like Like x 1
    • Useful Useful x 1
  3. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,642
    3,151
    East london
    You should be able to stand it on end... but if it's completely full in fairness you may get a slight leak. (You shouldn't but unless it's brand new or recently serviced it might not be completely pressure tight)
    you may find that emptying a little more regularly will help.
    If it's not leaking into the toilet housing then the smell will be down to a poor seal .. Probably.
    We use a small spray bottle with water and bio liquid in it that we spray before flushing ...
    We only use bio liquid in the toilet
    We don't get any evil smells ...
    First thing would be perhaps to strip the cassette and clean it's internals.
    You can buy a refresh kit for about 80 odd quid ... for that you get a new cassette and seat i think. Might be worth considering.
  4. WillH
    WillH Funster
    Feb 9, 2008
    1,720
    1,427
    SW Scotland
    I would have suggested a new lip seal but you have already fitted one, is it fitted correctly?
  5. namwaldog
    namwaldog Funster
    Jan 2, 2015
    469
    778
    Cumbria
    I serviced our cassette a few weeks ago by cleaning and oiling the seal and that cured it but what I have noticed since is this..
    That as I use the toilet, flush from the integral tank and then open and close the blade, there is a small amount of flushing water that is still running down the side of the toilet that then collects above the seal. I don't mind this as it makes for a more airtight trap above the cassette chamber. But the downside is that if you then slide the cassette out to empty it, the top slider covers this water from sight and when you turn the cassette on end, it looks like the seal is leaking.
    I find now that if, before I empty the cassette, I open the blade and leave it open for about 5 seconds before closing, prior to emptying this allows any water on the bowl to empty into the cassette before sliding it out.
    I hope this makes sense !!
    • Like Like x 1
  6. seanoo
    seanoo Funster
    Nov 14, 2009
    362
    217
    normandy
    s
    yup , i do the same
    • Like Like x 1
  7. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    2,067
    1,468
    Dover
    Demote that one to emergency spare and wash it out put it in the garage, then buy a new one with a refresh kit it is £20+ cheaper getting that way than buying stand alone cassette???? That way you have a bit of reassurance that you can still use it when a dump point is not available and it is full.
  8. gpz
    gpz Funster
    May 24, 2012
    94
    4
    north yorkshire
    thanks for all the replys guys i bought a new round top piece this is a circular disc that the flap sits in and i have changed that i have now found that the join between the lid and the cassette itself is leaking dont know whether there is a seal in there or not going to reseal the lid
