Burstner Control Panel (2 Viewers)
Mar 12, 2012
1,395
1,612
Bridgend, South Wales
Just started!
Sometimes when I try switching the Control panel on, it works first time. On other occasions it does nothing, no display, just blank.
Does anyone know why this happens? Or better still, know why this happens?
Cheers
john
Chris
21,056
279,039
10 years
It might be different to mine but ours is blank unless you put the little switch to 12v.
If its not on 12v the controls work but the panel itself doesn't light up.
aba
2,775
1,112
yorkshire
dec 2009
some digital panels won't power up if the battery is low.
StitchUp
Mar 12, 2012
1,395
1,612
Just started!
Thanks for the reply.
I only managed to switch it on once today! Then I switched it off.
Tried several times since with no luck.
No, there's no 12v switch on it.
So, I went to my E-Box switched it off, pulled the main 50amp fuse and secondary fuse. They tested fine with my meter. Put them back in and switched the E-Box on and as if by magic, it worked! Strange but true - I'm happy ::bigsmile:
I've hooked up to the mains now and gonna leave the heating on for a while.
I feel Spring coming on :thumb: and we must get more use this year, last year was a wash out.
In the E-Control manual it states the need for a disk battery as follows:
Burstner E-Control
Lithium Disc Battery
Diameter 20mm
Thickness 3.2mm
Voltage 3.0v
Capacity 180mah
Anyone know the batery number - aka LR *** or whatever?
John
StitchUp
Mar 12, 2012
1,395
1,612
Just started!
