BT socket (1 Viewer)
meexi
89
103
Angus,Scotland
Hymer B694
since 2011
Hi all,
A bit of advice please?
My broadband router is connected to the second socket that comes in the house but the third socket is the master one (seems strange already)
Should i connect my router to the master for better performance or get BT (get my wallet out) to put the master on the first socket?
Thanks for reading
Meexi
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Sounds like your wiring is incorrect, the master should be the first and where you need to plug in the router for best performance.
scotjimland
2,334
10,102
A Woosh bang
Unless there is a cable problem in the extension socket, ie chewed by rats or mice, or it's and extensive run, it shouldn't make much difference.
Easiest way to test is to plug the router in the Master Socket .. compare the speed between the Master and the extension socket using Speed test .. run the tests over a period of say 24 hrs.. also best to do the tests with the PC connected to the router using a LAN cable rather than wireless.
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Idealy it should be connected to the master :thumb:
Not long ago mine was playing up so I phoned Sky (provider) and they boosted my signal a few times but made little difference to the just over 2 meg speed,ended up with them sending a engineer out who tested everything and said I should be getting 5.5 meg --he ended up cutting the earth wire and thisimeadiately gave me the 5 meg :thumb: Told me the earth was not needed with modern phones ,but was needed yrs ago to make them ring but that had the effect of earthing and reducing speed :Smile:If you understand all that you understand more than me ::bigsmile::thumb:
all I can say is it works
terry
Apr 19, 2008
1,942
2,921
Kent coast Hythe
Rapido fiat based
brought first van 16 yrs ago
I was of the understanding whatever BT socket you fit the asdl connector this makes it the master socket and thus connecting broadband to this.
Bailey58
8,817
29,578
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
I have an old type wiring system with the incoming line going into an old junction box in the loft and fed off to various extensions radial fashion. When my connection started dropping out all the time Sky got the BT engineer in and he said the modem was hunting for a connection all the time through the configuration and wondered how I had ever got a decent connection. I rewired [STRIKE]the[/STRIKE] from the loft to a new master socket near the desktop and ran an extension from there back to the phone in the hall. The two other extensions in the place were cut off as we have long since had a rechargeable phone anyway.
scotjimland
2,334
10,102
A Woosh bang
I have an old type wiring system with the incoming line going into an old junction box in the loft and fed off to various extension radial fashion. When my connection started dropping out all the time Sky got the BT engineer in and he said the modem was hunting for a connection all the time through the configuration and wondered how I had ever got a decent connection.[HI] I rewired the from the loft to a new master socket [/HI]near the desktop and ran an extension from there back to the phone in the hall. The two other extensions in the place were cut off as we have long since had a rechargeable phone anyway.
I would have done the same.. and have done in the past..
but just just a word of warning before anyone starts rewiring..
Any wiring BEFORE and including the Master socket belongs to BT.. it is illegal to open the new type Master socket.. but you can take the face plate off and plug into the test socket.. this disconnects your extension sockets.. but don't touch any wiring inside..
If you mess up and have to call BT out.... big money
SandJ
1,799
818
North Yorks
Too long lol
As I have had ongoing issues with BT I will tell you what they said to me.
Try disconnecting everything you can and run the test from the test line, similar to what Jim is saying.
They said this should be the first socket that the main BT cable attaches to.
The test if the new type looks like this attachment
Run speed test with router plugged into this :thumb:
scotjimland
2,334
10,102
A Woosh bang
A pic is worth a thousand words..
Exactly what I was told when i had an on-going problem with a poor line ..
I was 99% sure it had nothing to do with the internal wiring as I had installed the extension myself.. but just to prove, and before paying out, I did what they said.. eventually they conceded it was a line or exchange problem and sorted it .. but it took a few weeks.. plus a few visits from a BT guy.
This is the official BT speed test site and the ONLY one they will pay heed to ..
Broken Link Removed
scotjimland
2,334
10,102
A Woosh bang
If you have an ongoing issue it is worth keeping the test results on Speed Test..
this is mine since July 2012.. you can see two periods when it was bad and needed fixed.. tonight is poor .. 1.26 Mb/s but that is due (hopefully) to it being a Sat night at peak time..
I wonder when we will catch up with third world speeds.. :RollEyes:
weekenders
2,658
1,967
Leicestershire
15 years
We have been having problems with our internet over the last few weeks, it keeps dropping of the internet and saying the "DSL" is not connected and check our instructions, I called Tiscali and they have checked the line and say there is no fault on the line.
Got fed up with intermitten internet and costing the earth for broadbandand phone line, so have today bought a 3 mifi so we can use it at home and away in camper, can also connect upto 5 things, such as phone, laptop, table etc
Tiscali can go and do one!!
scotjimland
2,334
10,102
A Woosh bang
I'd do the same if we lived in a 3G coverage area..
barely get a mobile phone signal let alone a decent data connection :Sad:
