sallylillian
That's not the same as the older ones, well done Steve
Can you post on this thread the eventual outcome of your follow through with Happich please. I have the same catch as yours on my Hymer and would also be interested in getting one with the additional burglar protection if possibleHi Steve,
This also looks an improvement on mine it has the addition of burgulary protection, and additional clip in the end. I emailed Happich UK this morning but have now had an email from my N+B German dealer and it's on DHL Xpress to me here in Sardinia.
I will follow through with Happich Steve as the added feature looks worthwhile.
Thanks for all the posts.
Michael
brilliant info thank you. Do you think replacing it will be an issue - ie mega glued? I always seem to find a solution and then it falls at the last hurdle!You star that's it. Now to get one
Would Durrwang have any ?I have Googled these catches without luck I am hoping someone has found them previously, MEKUWA make them but there is no part number and their web site is uninformative, I think they are used in many MH's. They hold the sliding front windows locked. Any clues appreciated.View attachment 104835
Did something similar but found it became a moisture trap which effected the runnerNothing really to do with your catch
For added security we have a length of ally strip which sits in the channel that the sliding window uses this prevents the window being opened (from outside) in case catch doesn’t catch!
Thanks Robert, that was the winning solution........ 2 Years ago! But the thought was there.Would Durrwang have any ?
That’s made of aluminium angle so the moisture can still run out as it should.Did something similar but found it became a moisture trap which effected the runner
