Boxer reverse light fuse ? (2 Viewers)
I Go Anywhere
ye948976C
Hi All, I have a 2009 Boxer Autosleeper sigma el, I am in the process of fitting a wireless reverse camera to work on my gps/dvd 7 inch player, I need to connect the trigger power sauce on the reverse fuse, all OK BUT when I try to piggyback the revers fuse (F 35) it "seems" to be live all the time, if I pull the fuse with reverse engaged the standerd reverse light goes out but when I put the piggyback fuse in it shows live in neutral. bit confusing I know but someone out there must have come across this. Thanks in advance.
Dec 6, 2011
11,598
25,452
South Wales
Coach built Adria
Hi welcome,
to make this clear, everything works as normal when the fuse is in place and its only when you put the piggy back in there is a problem?
if that is the case then the piggy back is the problem. it must either be faulty or its its not fitting correctly.
Jul 4, 2018
1,221
1,604
Bristol
Weinsberg
A few years.
The live feed is to the reverse switch (likely on the gearbox), you need to take the feed post this switch to switch on a reversing camera.
I
I Go Anywhere
ye948976C
Thanks guys for your input, Clivfog, that makes sense, will take the feed from the reverse switch, Cheers guys.šŸ‘šŸ‘šŸ‘
